Question about Hobart A200 Stand Mixer
Hobart a200 when loaded it does not work, do not spin. it works fine when oan is empty
  • Anonymous Nov 15, 2007
    only spin on 2nd and 3rd gear no 1st, can you help?
  • poptarts Dec 05, 2007
    Mine works in speeds 2 and 3, just not in speed one. I turned it on and off and went back and forth between speeds trying to get it realigned or whatever. A spoon fell in the bowl while it was running on speed 1 and it shut itself off. Now when you turn it on in speed 1, the motor still runs, but the beater doesn't turn.
  • 640 Answers
Will it move in any speed,i need to know this in order to troubleshoot your problem.im a hobart service tech and i service these mixers alot.
Posted on Nov 13, 2007
  • 1 more comment
  • anthony james
    anthony james Nov 16, 2007
    Where you see the beater shaft there is a nut next to it make sure that nut is not to loose or tight.was the mixer overloaded at any point?if this doesnt help you youll have to get into the transmission,i will walk you thru it.
  • anthony james
    anthony james Jan 08, 2008
    could you please tell me what the solution was,i dont feel that you should of rated me inappropriate after a month has gone by.
  • mouquee
    mouquee Nov 14, 2012
    This really helped a lot! Anthony James, you saved a lot of peaple for a $repair fee$. My mixerhas this and my kitchen mechanic friend told me to tighten the nut but not too tight,
I can't get the main shaft out of an A200 Hobart Mixer to service the lower bearing. Any advice?
Honestly, get someone in that knows Hobart mixers. The a200 is an amazing machine, but you will need to strip the entire gearbox apart to get to the bearings. Take this from someone who works for Hobart :)
Feb 19, 2018 | Hobart Food Mixers
Hobart A200
hi there,
did you make it sure that all part has been back into place and no small parts has been put away into its place.?
check for any loose screw,
Oct 24, 2008 | Hobart A200 Stand Mixer
Hobart 20QT guessing old a200 motor runs fine removed top cover to see but gears not working and mixer does not spin Any diagnosis Help greatly appreciated
The first vertical shaft has a brass gear that runs off the rotor. The ancient models had a spring loaded slip clutch built onto the gear. Upgrade it with a worm shaft kit which gives you a complete new shaft and fixed gears. I think it includes the upper and lower bearings. Maybe replace the grease if it has not been done. Or look for a sheared key on the worm shaft.
Feb 19, 2014 | Food Mixers
Hobart A200 mixer won't start
My fantastic guy just rebuilt my A200. He says it's likely that your back plate is slightly off center so that the center arbor is touching the windings-- any contact and the machine won't run. The tolerances are thousandths of an inch in there.
Nov 21, 2011 | Hobart A200 Stand Mixer
Hobart A200 mixer 1st speed doesn't work 2nd and 3rd work fine
Could be that a gear is missing (broken) on the shaft that works the 1st gear. Check out the schematic at
http://www.food-equipment.com/parts_Hobart_mixers.htm
It could be the gear HM2-748
Feb 22, 2010 | Hobart A200 Stand Mixer
Help? I need the Shop Manual for a Hobart A200 mixer. Thanks.
Ricardok45,I'm a hobart tech and can tell you nobody has ever bought hobart,they are a subsidary of illinois tool works.It's true hobart doesnt release any of their service manuals to the general public,however if you need guidence or parts i can help you.
Jan 15, 2009 | Hobart A200 Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
A200 HP rating
yes the early models had 1/3 the later 1/2 but I think it was more a marketing thing to keep up with competitors the 1/3 always worked fine
Oct 28, 2008 | Hobart A200 Stand Mixer
A200 problem
Check the planetary.this is the bottom part of the mixer where you attach the hook.
You will see two nuts; make sure their tight as the planetary may have moved down.
Also have a look below:
http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
Feb 04, 2008 | Hobart A200 Stand Mixer
Hobart A200
Make sure the planetary bolt (the bolt that sits next to the shaft is tight and all the way up,let me know i work for hobart and repair these units.
Nov 16, 2007 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
219 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
