? 9:37 https://www.youtube.com/watch?v=jsQcLya1YLQ
Jan 24, 2014 - Uploaded by jimthecarguy
No Start Cranks Ok No Injection Pulse 2002 Hyundai Accent Easy Step By Step ... and car cut off, but would not restart. it sounds like it is starving for fuel. ... hi nice video man . i have no sparkno fuel .u think its the main? it was ...
HI this is a rare case of a fuel pickup and delivery fault . problem arias to check are intank fuel pump and fuel collection bowl below pump mounting in the tank . Do check fuel pressure and fuel regulator. try filling 40L of fuel and test drive , If this resolves the problem check suction and feed pipe in tank .
If you have no issues with your battery cables, I would say it is a starter solenoid that is the problem. As long as it clicks, the start circuit from the ignition switch to the starter is working, and the starter motor tests good, so likely the solenoid is the problem. Is the electrical wire on the solenoid tight?
there have three factors may be cause the problem, 1.The filter is a source for low fuel pressure, because it is stoped up or is cloged. 2. The fuel pressure regulator is another. 3. The pump itself. Tech 2 software
the fuel filter is located in the fuel pump, its in the fuel tank. the same as the 2001 models of hyundai santa fe. sorry for the news, but thats where its at. good luck! heres the site for how to change, www.ehow.com/how_4506115_replace_fuel_pump_hyundai_santa
Please be as specific and give as many details as you can. The antifreeze should take around 20minutes to come to running temperature. And running temperature should be between 190 to 210 degrees. If Your car has become a fuel guzzler you will need to find out why. Gather as muck info as you can. How does the car start? Does smoke come out of the exhaust at an idle or at high idle? And if so what color is the smoke? Does the car idle uneven or rough? Is the engine light on and if so have you had the codes read? Auto-zone will do it for free. Is this car turbo charged? A defective turbo or air-leak, clogged air-filter, defective EGR valve, bad fuel-injector, or bad motor oil can cause poor mileage. I would like to help you but I need more information. Please let me know and good luck.
dear friend:if you got the filter unit in your hand then clamp the metal part in a vice and unscrew the filter part,sometimes it appears that it cannot seperate but it can.force and a filter remover will do the trick
