If this is a Ford vehicle it likely is a stripped gear in the blend door motor, which looks like a 4x4" box 1" thick held to the heater plastic box with three or four screws. This part can be ordered online for about $30 and is not difficult to replace on most vehicles.
The wires have a connector that is fairly easy to pinch and pull to release. The little motor box can be unsnapped and opened to view to see if the gear is not engaging or is missing a tooth before ordering the replacement. There will be grease on the gear so have a rag handy to wipe it to be able to inspect for damage. The identical cog gears are extremely difficult to find so don't waste your time trying to replace the little cog that strips out in these.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
its my 2001 lincoln navigator
