Question about Philco (R) 841.205 CD Shelf System
Hoe do operate the turn table
How do you get the turn table to turn on? I set it to phono and then what gets it going???
  • jojo2357 Nov 24, 2007
    I found the click and it still won't go. I put the dial on Phono and turn on the sound and clike the arm. What else can I try?????
Lift the arm off the stand and manually move it to the center of the player. You should hear a click and the turntable will begin spinning. To turn it off move the arm to the outside until you hear a click.
Posted on Nov 23, 2007
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Can I connect a tape deck *and* a turntable to the Sony STR-DE595?
If your turn table has a magnetic cartridge it will not work,Becuase the ner recievers are not equip with a phono preamp, They are equip to only use a crystal or ceramic cartridge in the turn table.
Sep 29, 2012 | Sony STR-DE595 5-Channel Amplifier
I HAVE PHILIPS AMP FR931 AND I HAVE A HITACHI HT4 TURN TABLE THAT PRODUCES A LOW VOLUME SOUND WHEN THEY ARE CONNECTED.
I can't find anything about the HT4 but it should be connected to PHONO (nowhere else) if it has a moving magnet cartridge and you should set the PHONO/LINE selector to PHONO.
http://www.p4c.philips.com/files/f/fr931_p00/fr931_p00_dfu_eng.pdf
Mar 26, 2011 | Philips FR931 Receiver
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
Were do i plug in my turn table into my stereo unit
It should have a Phono input - caution the input is sensitive to any voltage transitions and can amplify a signal just by touching the jack - thus be careful not to put a High signal into it. If you don't have a Phono input jack, you can use the AUX input. However, the signal might not be matched properly and you might have to set the volume differently - lower or higher.
Oct 25, 2010 | Audio Players & Recorders
Connected to turn table. having sound problem. At 99, sound hardly audible.
The bose as most all in one systems do not have an inbuilt phono stage. Phono especially MM type have a very low signal and an eq curve that gets altered in the phono stage. Without a phono stage (known as a phon pre amp) you will not get much fun from your turntable. To connect : turntable out - into phono preamp - phono pre amp out into bose line in/aux in
Sep 28, 2010 | Bose Wave Music System CD Shelf System
Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Jul 18, 2009 | Numark ttUSB Turntable
Sherwood RX 4105 no input for a turn table
Check for a line level switch on the turn table, it may be under the turn table itself lift the rubber mat and spin the table by hand, it may not have one or it could be on the back.
You can buy a phono amp that will boost the phono signal. Check at Radio Shack or google it.
Jan 31, 2009 | Sherwood RX-4105 Receiver
Turntable connection
you can not connect a turn table in any other input source other than Phono input my friend. turntable has got very weak signal thathas to be pre-amplified before getting a signal just right for a CD/Tape DVD input. you require a phono am to get an audio signal.
Mar 29, 2008 | Audio Players & Recorders
Turn table
Mine isn't working either, have you tried your speeds? I messed with mine and found out only the 78 speed works.
Dec 24, 2007 | Crosley Conductor CR73 Turntable
Philco (R) 841.205 CD Shelf System Logo
153 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
