Question about JVC AV-48WP30 48" Rear Projection Television
Leaking oil from lamp - JVC AV-48WP30 48" Rear Projection Television
  • 4 Answers
Fix leak or discard lamp.
Posted on Nov 16, 2007
Leaking oil
It is leaking from somewhere and getting onto the exhaust manifold or pipe. Prime suspects are the cam cover gasket, distributor shaft seal, or oil filter mounting.
You can buy a fluoro tracer dye eg
http://www.ebay.com/itm/SUPERCOOL-16525-Engine-Fluid-Leak-Detection-Dye-1-Oz-/222277586459
You give the engine a really good clean all over, add this dye to the oil in recommended amount, drive around a bit, and shine a blacklight lamp on the engine parts.
http://www.ebay.com.au/itm/Black-Mini-Aluminum-UV-ULTRA-VIOLET-9-LED-FLASHLIGHT-BLACKLIGHT-Torch-Light-Lamp-/152175749413?var=&hash=item236e61a925:m:m5bmKbE1HA0X6BZrPtCTZaA
The leak will glow. If it is everywhere too much, clean and repeat with less driving before checking.
Oct 15, 2016 | Cars & Trucks
I recently replaced my intake gaskets and after repairs im having transmission up shifting problems.
Check your Radiator coolant. If the coolant looks like chocolate milk, you have a cooling system leak into the transmission oil. Frequently misdiagnosed as engine oil mixing with coolant.
Nov 15, 2015 | Cars & Trucks
How to fix oil leak 2000 camry?
get it totally clean
drive 5 miles
look for leak
the key is to find WHAT is leaking.?
can be many things,
bad clogged PCV valve causing all things to leak or worse.
gaskets
seals
0-rings.
casing flaws that cause leaks (aluminum porosity issues)
until WHAT leaks is found
there will be NO costs, quotes, ever.
if not handy then just get it fixed, what choices are there?
not handy.?
sell it, ignore it. or?
no sane man quotes unknown repairs.
unless said man wants to eat losses. big time.
handy?
use IR dye in the oil with lamp IR .
then run car and see the dye marks as it leaks.
now you know both ways. (old and new)
leak on.
Feb 13, 2015 | 2000 Toyota Camry
What would cause a oil leak under pressure between the timing cover and the block?
on most cars
get it clean, drive around the block
then look, the gasket that leaks is the cause. replace it.
gasket ,o-ring or seal.
or use the UV dye and lamp tool, for $15 and find it more easy.
2 way there are. only.
clean and look, and dye and look.
besides total rebuild.
Jun 24, 2014 | 1999 Plymouth Voyager
My 2000 Jetta 2.0 is visibly leaking oil from above the oil cooler when the engine is running. Is it most likely the seal or could there be something else above the cooler that could be leaking?
let car cool down clean oil cooler make sure no oil visible. start engine keep looking see were oil is leaking from use torch or lamp if nessesary
Aug 02, 2011 | 1998 Volkswagen Jetta
Oil leak. Even when car is not running .the car is not smoking, but using an extreme amount of oil.
Go to any auto parts store and purchase a bottle of engine oil dye. You will also need an Ultra Violet Lamp which can be purchased at most pet stores, drug stores, and hardware stores. Follow the directions as labled on the bottle and you will find the leak source fairly easy and quickly using the UV Lamp as required
Mar 30, 2010 | 2003 Chevrolet Impala
Since exhaust manifold covers engine block, I have
buy some engine oil dye at any auto parts store
a uv lamp will be needed to use to locate the leak
this works best with newer cars and so many things in the way
Mar 09, 2010 | 1998 Chevrolet Malibu
Coolant leaking in the oil
Auto parts stores have dye to add to your coolant or oil to determine the leak. You will need an ultrviolet lamp also for this test
May 23, 2009 | 1993 Chevrolet Camaro
Oil low in red lamp
The substance is a clear antifreeze. The purpose is to keep the phosphors on the CRT cool so it wont burn. If the liquid was low, it means there is a seal or bladder leak somewhere. The tube needs to be removed and the leak can be patched with silicone rubber or the blader needs replacing.( check for cracks). Refill with coolant and re install. Use rubber gloves because the liquid coolant is hazardous to your health.
Nov 18, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
26 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
