Question about Philips 60P8342 60" Rear Projection Television
No picture We just got this Tv from a friend and it turns on but i have no picture we opened the back to check the fuses but they look fine. Just thought i'd ask and see if you could help. The person we got it from said it worked great but then after they moved and took it off the truck it stoped working. I"m not sure if the bulbs ar gone or not. i'm not sure what to look for when it comes to making sure they are still god.
    Problem Solver:
  • 20 Answers
Hello! zachwontstop,
Does the set have off the air sound, or audio? Yes or no? Please reply.
Posted on Nov 15, 2007
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
Not sure if its a picture tube problem or convergence problem. TV was working fine, put a DVD on pause, came back 10 minutes later and poof! Distorded picture almost 3D like. Shut it off and when it came...
Check the micro fuses that power the convergence board, one or two maybe open, While doing this also resolder the flyback transfomer and area around it. Check for cold solder joints in this area as well.
Replace any open fuse with 5amp same type. If fuse are good then convergence power board is faulty and needs serviceing or replaced.
Dec 21, 2009 | RCA HD52W58 52" TV
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Flyback making a poping noise
You can get the replacement Flyback at the following link, and they provide free instant messageing tech support to take you step by step with the replacemnet proceedure. You need phillips 32942 flyback, its listed in their flyback catagory.
Jul 27, 2008 | Philips 60PP9202 60" Rear Projection...
TV is DEAD without any prior symptoms
opening the tv you will see a fuse  it is surely open - you have to chenge with the same type and rating- pay attention to make this
just after did you disconnect the pewer cord from ac outlet- delfo
Mar 21, 2008 | Televison & Video
Picture and sound gone
your fuses may have blown off.
open the back panel and check all the fuses. There are a bunch of fuses in there, my tv has 5 altogether.
I hope this is the problem.
Feb 24, 2008 | Televison & Video
RCA Model P46924 I screwed up
Check connections at the HV distribution box (where the leads from the flyback connect to) and make sure all of these are in solid first. It sounds like a device is burnt open, since the over- current protection is not activated. This would allow the TV to still turn on, but with no picture. Of course you had installed a fuse too large, so that could explain that too- don't do this, you might have made the problem worse by burning out more components. Could be a bad horizontal deflection transistor or flyback transformer. Transistor p/n 2SC5148, flyback 239111 for this model, RCA P46924. You can find them on ebay for cheap.
Oct 29, 2007 | RCA P46924 46" Rear Projection Television
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Turns on but not picture or sound. Power LED blinks
Your set might not be producing the high voltage it needs to light up the screen , it might be missing the supply voltage the supply volts to the output transistor ,if this voltage is missing is because the transistor is likely bad(shorted) and it has opened a fuse or a safety resistor.If you are familiar with tv service you have a place to check but you are not too familiar be safe and call a professional,high volts circuits are dangerous.
Oct 16, 2006 | Akai PT4298HD Rear Projection Television
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
