Question about Philips DVDR3380/05 DVD Recorder
UNKNOWn disc type
I have a Philips DVDR3380 player/recorder which won't recognize any discs even though they were okay previously. Have tried new ones, used ones which I have recorded on and bought ones with films on. Have rung various TV/video service people who say they don't repair DVD recorders and have got no where with Philips as my recorder isn't listed! (only 18 months old).
Should I just chuck the thing out or is it repairable, and if so where do I go?
Many thanks
Re: UNKNOWn disc type
Me too - I've had a DVR3305/05 for just over a year and yesterday after using a lens cleaning disc it refuses to play anything !!! My advise is to stay away from Philips !!!
Posted on Dec 21, 2007
My solution: I took mine back to the shop and swopped it for an LG.
0 characters
3 Points
I have a Philips Home Theatre System, model HTS7200 which showed 'unknown disc' when I put discs inside.
hi I have a Philips dvd touch screen HTS7200 the lights on top for volume and play are not working ,the try is not opening ,there s no sound coming out thanks
Dec 17, 2010 | Philips DVDR3380/05 DVD Recorder
Hi I haev a problem with A Philips DVDR3380/05
Use Phillips own media this unit was designed with DVD+R/RW in mind, it will work with DVD-R/RW discs but Philips invented the + format.
If you are using the DVDR 3380 is recorded video to then upload to your PC the best program is TMPGEnc v4.0 Xpress it has its own function to scan source media from a DVDR, if you use +R or + RW media you don't even have to finalise it. This is only required if you want to play a DVD-R on another standalone
I have never had any problems with SONY and PHILLIPS media, generally speaking cheap unbranded media will have a higher failure rate , but you do get what you pay for when optical media is concerned.
Hope this helps, join for more tips and tricks concerning DVD's
Aug 18, 2009 | Philips DVDR3380/05 DVD Recorder
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Unknown disc error and whirring sound!
Do you leave the unit on all day and night on standby?
If this unit gets to hot you can experience this problem I suggest that you turn the power OFF totally until the unit cools down and try again. Normally 15 mins is enough.
Feb 01, 2009 | Philips DVDR3380/05 DVD Recorder
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
Does not recognise discs
If this disc that you are trying to use is a DVD+/-RW and it has been used a few times for DVD-Video or DivX then you can try to do a FULL ERASE using the excellent ImageBurn by lightining now at v2.5.0.0 it takes about 20 mins to erase a full single sided DVD
Hope this helps.
Jan 03, 2009 | Philips DVDR3380/05 DVD Recorder
Coming up with unknown disk
hello cavanimal
is this with all dvds you try or just the one you tried to play .
can you play and dvds at all .
are the dvds regions stopping you playing the disc.from other countries .
Jun 22, 2008 | DVD & Blu-Ray Players
Wont record on new disc
I think you need to format your new discs.
Jan 21, 2008 | Philips DVDR3380/05 DVD Recorder
Philips DVDR 3380
the laser mechanism must be changed
Jan 17, 2008 | Philips DVDR3380/05 DVD Recorder
Philips DVDR3380/05 DVD Recorder Logo
696 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
