Question about HP Photosmart 733 Digital Camera
Broken battery door
They told me it is cheaper to buy a new camera than fix a plastic battery door.
  • 4 Answers
Re: Broken battery door
Go to Hewlett Packard online, they might be more able to help.
Posted on Jan 04, 2008
0 characters
3 Points
I dropped my Nikon Coolpix L1 camera and cracked the battery door. Now whenever I take a picture, I have to hold the battery door manually so it will stay shut and recognize the power of the battery. I'm...
So other than the broken battery door (very common) it works just fine?
Well you could go and spend a fortune on another camera. Or you might decide that a few cents worth of sticky tape to hold the door closed is far better value.
I've fixed the same fault on similar Nikon models before by fashioning replacements for the broken plastic tab/loops using shaped short lengths of paper clip wire glued into carefully filed channels using epoxy resin (the designs vary, but Nikon keep making them of plastics with all the structural integrity of cheese!). Doing it that way makes a far neater and original-looking job of it and restores normal functionality.
Mar 11, 2011 | Nikon Coolpix L1 Digital Camera
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
Broken memory card/battery door
I found this site with some replacement parts and battery doors looks the same. I dont know if is original. I also have the same problem. If any of you have found the part in a different web site.. just let me know please.
Jul 31, 2008 | Digital Cameras
Battery door doesn't close tight
Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
Jul 10, 2008 | Digital Cameras
Battery door broken.
Personally, I would go to your local hardware store and buy some electrical tape (the black stretchy tape about as wide as masking tape). Just use that to hold the cover shut. It's a lot cheaper than getting it "fixed", and it's just as good.
Nov 28, 2007 | Philips PJ44432 Digital Camera
ViviCam 2.1 Mega Pixel Digital Camera...broken battery door
just get the battery cover fix by taking your camera down to a camera shop like jessops. there is no need to get a new camera.
Nov 25, 2007 | Vivitar ViviCam 4345 Digital Camera
Broken part on camera
I suspect you won't be able to buy the part. However, you might be able to fashion a suitable piece of plastic and glue it in place using an expoy resin adhesive like araldite. Or use gaffer tape to hold it shut! Samsung may be willing to repair it but it'll probably cost you.
Oct 28, 2007 | Samsung Digimax D53 Digital Camera
Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Seeking Canon Powershot A520 Battery Door.
You can probably pick up a "broken" A520 on Ebay for $20 or less and use the parts from it. There are always some listed, but there are a few bidders who are in business picking up these cameras and "fixing" them to sell again. Good luck.
Oct 14, 2007 | Canon PowerShot A520 Digital Camera
HP Photosmart 733 Digital Camera Logo
65 people viewed this question
Top HP Digital Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Digital Camera Expert? Answer questions, earn points and help others
