Question about Opticon LGE1105RHHS-000 Handheld
No green ready light
After replacing a worn out trigger assembly my HLT/ELT1105/004 ready light doesn't light up when I plug in to the wedge (which is powered up).
This has happened with two different repaired scanners.
Everything works when I plug in an un-repaired scanner.
Do I need to reset something?
  • 244 Answers
Re: No green ready light
There are two different type of port usually experience this particular problem.
1) If you use the scanner to com1 computer port
2) If you use the scanner to com1 cash register
The only way to settle the situation is to use the manual barcode scanner default settings.
1) Setting up default for com1 scanner
2) Setting up default for com1 cash register.
If you barcode still experience the problem you need to contact the manufacturer on that model or the reseller where you bought the said device.
Probably, the device being situated in critical effects that your scanner would not able to determine where it will send the data from your barcode scanner.
Please rate me solved if you like my suggestions.
Best regards,
Posted on Nov 17, 2007
0 characters
3 Points
My gun want scan/
Probably the trigger module. The small switch mounted on the PCB assembly directly behind the trigger in the bottom shell goes bad.
Oct 22, 2013 | Symbol PDT6842-NIS632EU Portable Data...
Need a diagram on how to replace light bulb in clock in EL Falcon dash.
To replace the clock light bulb on 2001 Honda Accord, you will need:
  • Screwdriver
  • Replacement bulb
  1. Remove the clock assembly in the 2001 Honda accord. Pry the clock assembly off by wedging a flathead screwdriver into the edge and prying off the cover. Work your way around until it comes off.
  2. Remove the old bulb by pulling it out of the socket. Dispose of the bulb.
  3. Replace the bulb with an equivalent bulb. Simply push the bulb into the slot. Be sure to take the bulb with you when you purchase a new bulb so you get the exact bulb. Purchase a bulb with the same voltage. Although a bulb with different voltage may work, it can burn out more quickly.
  4. Replace the clock assembly. Line up the clock assembly over the bulb and press firmly on both edges to attach it back to the 2001 Honda Accord dash.
  • Place masking tape on the edges of the dash around the clock assembly to protect your dash while you are removing the assembly with the screwdriver. Remove the masking tape when you are finished replacing the clock light bulb on your 2001 Honda Accord.
Jul 05, 2011 | Falcon 4420
Having opened the top pannel to clean lens, my Laserjet 5000N came up with this error message. "printer error 52.0"
52 is a scanner error, the scanner here is actually a rotating mirror assembly that 'scans' the laser right to left. (as the paper moves top to bottom)
Make sure you did not smudge the lens or move it too far in any direction. Gently use a clean q-tip or equivalent to 'reclean' the lens.
Then, power down, count to 10, power up.
Same error?
Power down. Find green checkmark button, power up, when memory starts to count, press and hold green checkmark button until ready, data, and attention lights all flash. Release Green checkmark button, display should say "Select Language".
Press Down arrow once, display should say "Cold Reset".
Press select and wait for a reboot to complete.
If you still have the error, then you have a physical problem and will need a repair tech to fix it.
Aug 31, 2010 | Barcode Scanners
The trigger on my mc9090 rfid scanner is not working consistently. It seems to not depress all the way at times and seems stiff to react.
Hello gschershel. This is a farily easy problem to solve. But before you do anything, you'll want to check with Motorola/Symbol or whoever you bought the unit from and see about the Warranty for your MC9090. Most sorts of tinkering can void warranties and I'd hate to see that happen to you. So, make sure you check on that before tinkering. Aside from that, there are a few reasons this can happen. Something in the trigger assembly could have broke and is sticking, or you might just have some goo around the trigger. I suggest to all of my clients before sending their units in for repair to take a straight-pin or similarly small object and run it around the tiny gap between the trigger and the handle. If there is any offending goober in there that is causing the problem, this will work it loose. If that isn't the case, then depending on your exact model, the handle may be separate from the rest of the unit. If this is the case, then taking the handle off to see what's going on in there is as easy as four screws, so that is an option if it applies to you. Again, I only suggest this if your unit is NOT under warranty. IF it is, you should have already ignored the rest of this and sent the unit in to Moto/Symbol or your vendor. If all else fails, you at least know that something has gone wonky internally in the trigger assembly. I sincerely implore you (and all my clients) to NOT crack your unit open and go rooting around in there unless you've done it many times before or have a serious knack for electronics and have lots of experience in that sort of thing. Instead, contact your vendor or someone authorized to repair your unit and simply tell them that the trigger or handle needs replacing. I hope i have at least helped you isolate the problem. Good luck!
Jan 09, 2010 | Symbol MC9090-G RFID Handheld Barcode...
I have an LS4071 with an RL474 base. The cable has the PS2 Keyboard end. Scanner gets a good scan but no data goes into the computer. Testing with notepad open to receive the scan.
When I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector) I received the error message that my computer could not recognize this external hardware. I went to and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Mar 11, 2009 | Symbol LS 4071 Handheld
LS2208 keyboard Wedge only works with PC keyboard connected
one of the settings in the code book is to emulate keyboard function. turn this on and you do not need to have the keyboard plugged in
Sep 24, 2008 | Symbol LS2208 Handheld
Laser does not trigger
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Feb 28, 2008 | Symbol MC1000 Barcode Scanner
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Scan button do not function
go to 1 - Test Apps
go to 6 - Next Page
do the tests now ;)
Nov 23, 2007 | Symbol MC1000 Barcode Scanner
Actually HHP IT4410 LR
Have you tried reinstalling the drivers? Or downloading the latest driver from the manufacturers website? My father had the same problem with his scanner, and all he did was reinstalling the drivers and it worked fine afterwards.
Apr 10, 2007 | HHP IT4410HD
Opticon LGE1105RHHS-000 Handheld Logo
175 people viewed this question
Top Opticon Barcode Scanners Experts
Brian Sullivan
Brian Sullivan
Are you an Opticon Barcode Scanner Expert? Answer questions, earn points and help others
