Question about Lexmark E234 Laser Printer
Paper jams When trying to print the paper keeps getting jammed, even if there isnt alot of paper in the printer. E234n.
  • helokite2 Nov 13, 2007
    I have done that. I think I may need a repair. Thank you for your help.
I had the same problem and fixed it by giving the printer a good cleaning and turning the paper pickup tires (under the front of the printer, above the tray) inside out (they were showing some wear).
Posted on Jan 17, 2008
  • 85 Answers
Fan your paper.
Fan:
Meaning take the paper in your hand and wave it around or page thru the papers, This puts air between the paper to prevent jams.
Make sure you do not over due the paper in the tray. Try lighter paper weight.
Posted on Nov 13, 2007
  • Shawn Bowman
    Shawn Bowman Nov 13, 2007
    Sounds like it. no problem, good luck.
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Paper jam on my lexmark e234n from try one all the time , even when i switch trays. why ! thank you :)
check the entire paper route as it goes through the printer, especially at the edges, sometimes the smallest scrap of paper can block the sensor so the printer thinks there is a jam
May 05, 2011 | Lexmark E234n Laser Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Turned it on and it says paper jam. There is no
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
My printer suddenly stops printing then it says paper jammed even it isnt... i try not to load paper but still that message appears.
the paper sensor pin is jammed up in sensor so it detects that the paper is still there.even though its not there.get the printer serviced so that the sensor moves freely.this will solve the problem. please do not forget to rate the solution.thanks
Jun 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
Paper jam indicator keeps appearing and there is no jam.
SOMETIMES THE PRINTER WILL READ THAT IT HAS A JAM IF SOMETHING LIKE THE INK ISNT CLICKED IN TIGHT OR SUCH. IM SURE YOU MIGHT HAVE TRIED UN PLUGGING IT FROM ITS ACTUAL POWER SUPPLY BUT IF YOU HAVENT I WOULD TRY THAT, IT COULD RESET THE WHOLE THING. IF THAT DOESNT WORK I WOULD JUST GET THE PRINTER IN GOOD LIGHT AND OPEN ALL COMPARTMENTS, THERE COULD BE THE SMALLEST PIECE OF PAPER JAMMED SOMEWHERE YOU CANT SEE OR WOULDNT EXPECT THERE TO BE ONE
Jan 09, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Lexmark E234 Laser Printer Logo
296 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
