To replace an ink cartridge using the
ink button, follow the steps below.
1. Make sure that the printer is on. The
power light should be on, but not flashing.
2. Lower the output tray, then open the printer cover.
3. Press the
ink button. The print head moves to the ink cartridge replacement position, the
power light begins to flash, and the
ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
4. Open the cartridge cover. Pinch the sides of the ink cartridge that you
want to replace. Lift the cartridge out of the printer and dispose of
it properly. Do not take the used cartridge apart or try to refill it.
5.Remove the new ink cartridge from its protective bag. Place the ink
cartridge vertically into the cartridge holder. Then, push the ink
cartridge down until it clicks into place. Do not apply excessive force
to the cartridge.
6. When you are finished replacing the cartridge, close the cartridge cover and the printer cover.
7. Press the
ink button. The printer moves the print head and begins charging the ink delivery system. The
ink
lights start flashing. This process takes about one minute to complete.
When the ink charging process is finished, the printer returns the
print head to its home position. The
power light will stop flashing and remain on, and the
ink out light will turn off.
The
power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
