Question about Radio Communications
President uniden hr 2510 ham radio
Recieve no transmit hr 2510
  • potts024 Nov 30, 2008
    i have the same problem. Got this 2510 and everything works great but no tx. it does rx. any help?
  • 494 Answers
I know these are old posted questions but here are some new answers..... Simplest first! Make sure the TX button is not engaged, if it is then the radio will not work correctly.
Second would be a bad final or driver, this is a tough fix as these parts are tough to find, the parts are no longer made. A fix has been devised using MOSFETs but I have little details on this.
Third but not last is to do with age and environment, a glue was used to stabilize parts to the boards, wire and coils typically. This "glue" will break down over time and exposure to moisture and become conductive, shorting out parts and also corrosive, making copper wire and traces come apart.
Lastly, incorrect bracket knobs with screw threads too long can actually "crush" the PC board and break the PC copper traces.
Dropping the radio is not good, cracked boards and broken wires in hidden places.
Repairs can be made on all these but you need a tech that has experience to find these.....
Posted on Apr 06, 2010
Posted on Jan 20, 2010
The problem with 2510 radio is being left in tx mode . the transmit button.bought one on ebay parts or repair finals burned up plus other three 2510 boards off ebay same thing .i had to pay my repair tech 50.00 bucks for a transmit final. oh well hellcatcher
Posted on Jan 18, 2010
Can be caused by many things. Usually the first thing to suspect is blown power output transistor/s. Was the radio transmitting into a properly matched load? ( ie. an antennea designed for the transmit frequency) and was the VSWR monitored?...pretty obvious stuff for Hams to know...
My 2510 started to have xmit problems that surfaced as audio/transmit signal quality problems...than soon progressed to no RF. I dont know if this rig is subject to occsillation problems...I have also heard that this problem is often causede by a capacitor goinng bad inthis model..probably an electrolytic..but I dont know which one...I have not dug into my set yet, but signal tracing the problem would be a good start.
Posted on Jul 03, 2009
Posted on Jun 15, 2009
D104m6 wire it to 2510 cb
Pretty sure it can be done but you need a wiring diagram for the radio pinout and the mic. Best leave it to a CB service shop.
Oct 11, 2014 | Uniden 5 Pin Cb Microphone Fits Hr2510 Hr...
2510 cb wire to its stock mic
Do not understand your question? Need more info.
Oct 10, 2014 | Uniden 5 Pin Cb Microphone Fits Hr2510 Hr...
My uniden president hr 2510 tx is stuck on
theres a VOX button on the front of the radio, is that activated? if so press it to shut it off
May 25, 2014 | Radio Communications
My 2510 president uniden won't star,what is the posible cause??
What do you mean by star? Most of the time the problems with 2510's lincolns and 2600's is white glue on board has become conductive. and bad electrolytic capacitors. Please give more info on problem.
Oct 28, 2013 | Radio Communications
I need the schematics for a Uniden President Washingtom cb radio
I have the schematic, in a pdf form. Just need a way to send it to you. email/ftp/ send me a self address envelope ill print it out its not very big.
Nov 27, 2011 | Uniden PC78ELITE 40-Channels Base CB Radio
Looking tor owners manual uniden HR 2510 10 meter mobile transciever
Follow the yellow brick road...:
Jun 05, 2011 | Uniden Radio Communications
Uniden uho73sx always says BUSY on the display???
There may be a wire inside that is pinched shorted or not connected properly. The uniden HR 2510 use to have the same issues on the LCD display.
May 15, 2011 | Radio Communications
President HR-2510 will not transmit or recieve
Hi Darrel,
Since you didn't say if you have ever used this radio successfully before, I have to assume it is "new to you" and that you have never seen it work or used one like it before. Start with a few basic settings below:
Turn Squelch to minimum.
Set RF Gain (if present) to maximum
Set Mode to AM or FM
Set volume to 1/3 up
Connect to 50 ohm dummy load.
Turn power on. Hopefully you hear static. If not, try SSB or FM. Still nothing? Try connecting to an external speaker.
Chnage back to AM or FM mode. Key mic check & for transmit indicator. If none, change mic or manually short the PTT contacts in the mic or at the radio to see if it can be made to xmit.
If no xmit - insert SWR meter between xmitter and dummy load. Try to xmit on AM or FM again while watching SWR forward power, if none indicated, xmitter is probably defective.
Replacing parts in a xmitter is not recommended. You'll need an FCC license and a fair amount of expensive test equipment to test repairs, set power levels and deviation and perform an alignment to be sure you aren't causing interference on other frequencies and bands.
You'd be better off bringing it to a radio repair shop for repairs and an alignment.
Sep 29, 2009 | Uniden Radio Communications
Electric diagram
HR2510 is very close to the same radio. Email me if you need the 2510 diagram.
Sep 09, 2009 | Uniden Radio Communications
How many amps does the Uniden President LTD 715 need to operate/ transmit?
A 6 amp fast blow fuse is usually enough for any marine VHF radio.
Jul 01, 2009 | Uniden Boating
Radio Communications Logo
2,975 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
