Question about Epson Stylus Pro 9600 InkJet Printer
Paper out indicator
The paper out indicator stays lit. Removing paper roll, restarting, etc fails to help.
Re: paper out indicator
I do know what's going either, but to get around this I have to keep paper in the loaded position. So turn the printer off, put a letter size sheet of paper in (as though getting ready to print), turn printer on again, and now the printer gives the "press pause" msg, press it, the paper will load up, and then the printer reads again, "Ready".
The printer just seems to want paper in it or else it won't read "Ready".
Posted on Dec 27, 2007
0 characters
3 Points
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
...Still "paper jam". I did
This article in the Lexmark website on How to Troubleshoot a Paper Jam or Misfeed on the Lexmark P4350/P4330 Photo All-In-One will help you fix the paper jam problem. However, if problem continues, there could be some sort of foreign objects that fell into the paper feed system. Grab a flashlight and look into the feeder for any foreign objects that's in the paper path or, if you are capable and willing, carefully lift your printer upside down so the foreign object will freely roll out from the feeder.
Apr 03, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have a Dell s200n printer, the green light bleeps and states load/ remove paper, I have tried loading new paper removing etc however nothing works, I have reset the machine and still the error stays, can...
you have a paper jam or a bad paper sensor. open the back/rear and look for ajam in the fuser. if no jam you have to call a rinter tech to find the bad sensor
Dec 30, 2009 | Dell S2500N Printer
If the alarm light is lit constantly it usually indicates that the paper is not loaded, it should go out when paper is loaded. If it is coming on and staying on for a while during printing then there is a problem with the paper out sensor and it may need cleaning. If it is flashing then the other lights that are lit indicate the problem.
Nov 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Showing paper jam at master disposal NOTHING THERE
Remove the power cable from power source for few minutes. If its a temporary software issue it will get sorted out. Pull out master roll and reinsert it. Check wether you have properly inserted the master disposal tray or not. If these don't work ask for further assistance.
Jul 17, 2009 | Riso RZ220 Duplicator
Constant Initialization
i would start by removing all paper trays, optional memory, network card, etc to see if it boots up then.
Mar 12, 2009 | HP LaserJet 1600 Printer
Paper Jam? Print quality
If the toner wipes off the printed pages, then the fuser is the problem....not hot enough or enough pressure to heat the toner to the paper. I would try to reseat the fuser...make sure it is making good electrical contact. I have also seen the paper actually wrap around the fuser roll, which would cause the same careful removing the paper if that has happened...the fuser roll can be easily damaged !
Jan 22, 2009 | HP LaserJet 2840 All-In-One Printer
Brother HL-2040 All LEDs stay lit and the printer no longer works
Turn it on and when all the LEDs light up, THEN press the Go button. One or more LEDs will stay lit and the others will be off. Look in the user manual (you can find it online at the Brothers site if you don't have one). There is a chart in the Troubleshooting section that will tell you what problem your particluar combination of "lit" buttons indicates. It may suggest fixes, or depending on the problem, tell you to see a repair person.
Nov 19, 2007 | Brother HL-2040 Laser Printer
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Printers & Copiers
Epson Stylus Pro 9600 InkJet Printer Logo
139 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
