There is a pic under the hood that showes the corect way to run the belt. over and under diferant pulleys. figure out the corect way it goes and use a breaker bar to pull the tenchenor so you can slide the belt on, then let go slow and your done. the soring holds the pulley at the exact right tension. you can do this it's not that hard... good luck
saw
Thx sawdust for info. however i don't see a 1/2" drive socket hole to insert 1/2" breaker bar on belt tensioner like on many earlier models ??
serpentine belt diagram
