Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 projection TV volume control
The front panel controls seem to stuck on my TV. I push the volume control to increase or decrease the sound and it will change momentarily but revert right back to the same setting within seconds. None of the other front panel controls seem to work and neither does the remote. Only the off on button.
I tried the system reset button but that did not correct the problem.
  • Anonymous Mar 17, 2014
    when volume is pressed on remote it appears on screen as if its working but volume does not increase or decrease.
  • Anonymous Mar 22, 2014
    There's no sound
  • 1,694 Answers
Check owner / operator manual for "panel lock" selection or
go through menu pages until you spot it........
This selection is made so guests or children cannot operate tv.
In case this suggestion fails, you might try hard reset = unplug
AC cord overnight,then try again...........T.
Posted on Nov 13, 2007
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Model #57733 - Volume will randomly increase without notice. Remote control no longer communicating. Have tried the reset button.
the volume control is increasing randomly on it's own because the volume button on the TV is partially stuck in, that is why its coming up occasionally. This same thing may also happen to the remote control of the TV.
Use your find to rub the buttons on the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Aug 25, 2011 | Mitsubishi WD-57733 57" HDTV
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The screen seems dark and blurry
take off the front panel carefully, usually 2 screws around the controls. Next, stick your head in and look at the red green and blue tubes. see if they are dirty? if, not look further into the tube using aflaslight and see if there is a white pasty looking substance inside. IF so, you need to clean as you have bacteria growing in the cooling fluid. A big job and you need the gaskets, can order from Mitsubishi tech support..good luck be careful.
Mar 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Removing front screen.
Good Day;
You say you want to find LCD panel? On a WD- 52525 MIT's. Why do you want remove panel? What Brand & model do you have??
Sep 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD-52525
first unplug and let it sit for a couple of hours and then try again.
Jan 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Control board assembly (internal - not front panel)
Try reseting the remote.....hold down the power 00, or 01....then release the power button......Or maybe the parental control is engaged...........On this model all the boards are interconnected in one shielded unit.....That a certified experienced tech wouldn't want to dis-assemble/reassemble in the home.
Jan 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Television Model # WD-52627, Serial # 107108 - TV Not Responsive
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Aug 18, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
