SOUNDS LIKE TUNNING PROBLEM..TRY RUNNING IT ON A LONG TRIP WITH THE HIGHEST OCTAIN YOU CAN FIND PREMUM FOR SURE AND SEE IF THAT CLEANS IT OUT IF NOT YOUR GOING TO HAVE THEN CLEANED BY SOMEONE WHO KNOWS WHAT THEY ARE DOING..YOU ONLY NEED TO CHOKE IN COLD CLIMATES..TRY ONLY HALF A CHOKE INSTEAD OF FULL CHOKE..THE CHOKE DUMPS RAW FUEL INTO THE ENGINE FOR COLD START UP ONLY..MAYBE CHOKE NEEDS ADJUSTMENT..
Testimonial: "Thanks its a start. Im not sure why but my sled info was not part of my msg. Its an 04'900cc Arctic Cat 1M I changed the jets as it was running very rich and not sounding clean. Now it sounds good and snappy but hates to start in the morning. I wind up having to get a buddy to hold the throttle a bit while I pull her over and it grudgingly starts. The choke seems to flood it right away. Before doing the jets it started first pull :("
SOURCE: J.D snowmobile 340 73 carb wont idle appears internally clean.
my guess is that its not the carb at all but it might be the gas line in side the tank is cloged to the point whare you need to have it on choke in order to pull enough gas to the carb which would be the reason for it not wanting to come back down to idle quickly or it could be the fuel pump is cloged and if you tried that already than the fuel adjustment is way off and will need to be adjusted while a friend or family is keepin it running
and if that is not the problem than email me.
good luck:)
SOURCE: This bike is a 2007 and is extremely cold blooded
Try adjusting the fuel/air ratio screw on your carb. i would start by turning it 1/4 counter-clockwise to allow more fuel to flow in.
Testimonial: " there is no air screw on this model for some reason just a fixed jet inside the float bowl.Thanks anyway."
SOURCE: Hello I have a 1996 Suzuki DR-200 and recently put
G'day mate the 1st thing i would go for is float level then compresion if it does have the **** it wont take the fuel in , rules are if it has **** ( induction ) Squeeze (compression) Bang ( spark) and Blow (free exhaust) then it should go, if it was running to lean there is good chance it has a burnt exhaust valve which will greatly drop the compression/induction, also check the valve clearence. hope this helps
SOURCE: '97 rstd cold start, full choke,, cyl 3&4 do
low milage tells me most likley the carb is gummed up. You may need to remove and clean out or try some fuel injection cleaner. Use twice as strong as recommended. Your description points to not enough fuel when cold which is when it needs the most. If your handy I would remove the bowl and blow out all chambers and tubes with brake cleaner.
SOURCE: flooding
put choke to half position NO throttle turn key works every time
.If its flooded full throttle NO Choke keep winding till it starts .
Its an 04' Arctic Cat 900 1M Sled...not a motorcycle.
