You are correct. If the inducer motor is warm, but not running, it has seized up. If you replace this yourself, I also suggest that when you replace the inducer fan, check to make sure the secondary heat exchanger isn't clogged, or the condensate drain(s). If you have an HVAC contractor replace it, he should do this for you. It shouldn't run more than $350, to have it replaced and he can check for clogs (The price I'm quoting is for standard hours).
You can check this yourself by running the inducer fan without it being attached to the furnace, then attaching it to the furnace. If you notice a significant reduction in airflow, then you have a clogged secondary heat exchanger. I've run across this situation before on this particular model. The owner recenly replaced the inducer motor, but couldn't figure out why he was still having problems. I suspect the clogged heat exchanger contributed to the inducer motor to failing previously, and feel It would definitely be worth checking while you have the fan removed to help eliminate any future problems that could result from this, including heat exchanger failure. The manufacturer of this unit actually recommends you clean the secondary heat exchanger every year, but this is overkill if your furnace was installed and set up properly. I'd recommend doing it every 10 years and you're at that mark now. Instructions on how to do this are in the manual for this unit if you have it. Otherwise, e-mail me at
[email protected] and I can send you a copy.
Finally, check the limit and flame roll out switches after replacing, as they could have tripped when the motor failed.
