Question about Brother HL-5270DN Laser Printer
Hl5270 clear "replace fuser" error
I have fitted the fuser and still the message appears, please help ?
  • marvel59 Apr 28, 2009
    i have the same problem: on my printer display appears the messages "replace de fuser" and "replace the laser" alternatively. The machine works correctly and so good. how can I enter in maintenance menu to reset counters? please help me.
To reset any of the consumables on your HL-5270 you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu.
Posted on May 12, 2009
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
I have an hp 4300 with a 13.12.00 error when the duplexer is installed
Here is a copy of the 13.12 error troubleshooting steps from the service manual.
1. Press the HELP ( ) button for
detailed information about
clearing the jam.
2. Press the UP ARROW( )
button and the
DOWN ARROW ( ) button to
step through the instructions.
3. Check the paper width and
fuser delivery sensors
(PS106, PS108) and verify
that the sensor arms move
freely. (See "Location of
printer switches and sensors"
on page 336.)
4. Check the inside of the
duplexer for scraps of media
that might have torn off when
a jam was cleared.
5. Replace the media-size
sensor (PS106) and fuser.
See "Location of printer
switches and sensors" on
page 336 and "Fuser" on
page 162.
6. Turn the power off. Remove
the duplexer and turn the
power on. If the error
message persists, replace
the DC controller PCA. See
"DC controller PCA" on
page 181.
7. Replace the fuser (PS108).
See "Fuser" on page 162.
8. If the error message appears
frequently, see "Paper-path
troubleshooting" on
page 295.
Feb 07, 2013 | HP LaserJet 2420 Printer
HP LJ 5500dn printer-replaced black toner crtrdg,w/OEM tnr crtrdge, recvd control error mssge 'clean fuser input',which we did according to online HP instructions, & another 'youtube'...
Hi Donna
It sounds like the machine still wants a new black toner, normally this message clean fuser input" clears whent he machine reconises a new Original non refilled cartridge being fitted, so it sounds like you have either a faulty cart or a non gen HP cart fitted like a aftermarket or refill. People often get confused that a cart they are using is OEM when in fact it is a OEM empty that has just been refilled or it isnt HP at all usally marked as "for use in HP" so please ensure we are in fact fitting real toners, if you fitted a HP one you would have to tear open the box it comes in.
If it was call I would unplug it from your pc, power it off then on, remove all your cartridges and ensure they are original HP, I'd remove the fuser and clean the discharge lamp area see HERE.
Id replace any consumable that look suss or was leaking. I test via the control panel ie menu/ information/ print supplies status. Can you get a status page out or does the error stop you?
If it still failed the first thing to do would be to replace black toner cart with another as I think your is faulty. If it is real HP then is a gaurantied item so take it back for replacement.
If a tec was their just 3 days ago it too should be covered, most companies like mine allow recall warranty on repair work on same fault if it occurs within 30 days or original call.
Here your user manual and a pic below of what it wants cleaned but mind you normally a new toner clears the message regardless, please note this error wasnt included in original machine realease it was a firmware update that added it so it may not be listed in early prints of manuals for your machine.
Let me know how you go the more info the better
Cheers
Steve
Dec 10, 2011 | HP Office Equipment & Supplies
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Lexmark c540n printer that has the fuser error of 122.03 service fuser error how do i clear it on my machine I don't have tick btn any help would be great
you can reseat the fuser, and see if the message goes away. Or you will need to replace the actual fuser assembly. unfortunately you can't just remove/clear the error. see picture attached as this is what the fuser looks like
after you replace it let me know if you still receive the error.
Oct 15, 2010 | Lexmark T632 Laser Printer
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
Clear fuser life warning C524
Replacing the fuser
When 80 Fuser life warning appears on the operator panel, replace the fuser soon. Make sure one is on order. See
Ordering a fuser for more information.
When 80 Replace Fuser appears on the operator panel, replace the fuser immediately.
......From the Lexmark users guide.....
Dec 23, 2009 | Lexmark C524 Laser Printer
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
Apr 11, 2009 | OKI C5550N Multifunction Printer - Color...
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
LCD Message - System Error E000
THE FUSER HAS STOPPED WORKING(wont warm up) REPLACE FUSER
Nov 09, 2007 | Canon imageCLASS D880 All-In-One Laser...
Brother HL-5270DN Laser Printer Logo
2,187 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
