Question about Toshiba Satellite A105 Notebook
Contrast How do oyu set the contrast onthe Toshiba a105 laptop the screen is to dark?Thanks!
    Problem Solver:
  • 9 Answers
Try to set the brightness Fn+F7.
Or use the vga control panel to set it. Control Panel | Display | Setting tab | Advanced | (Vga Type) tab
Posted on Dec 01, 2007
Toshiba A105 - S4334 laptop,imediately on startup the screen goes so dark I can't see anything but a shadow of the screen,if I clsoe lid and open again I can see the display but only for a few seconds.Is...
Hello wall flower hi, when you turn on the laptop, did you see the start up screen clearly? can you read words on the screen, and then it goes dark? If this is the case, check first the Fn key with the corresponding display for projector, (usually Fn+F5) this combination key is used to display the content of your computer to the LCD or Projector, IF not such a case, it may be problems with your laptop inverter board that powers the backlight. Check your bios settings also.
Feb 12, 2010 | Toshiba Satellite A105-S4334 Notebook
Dark screen
Check to see that the brightness is turned up. Refer to the user manual of how to set the brightness. Call the tech support for your computer if you cannot resolve this with the instructions.
If there is a defect, most likely the backplane lamp, and or its power supply may have failed. This can be a bit expensive to service.
You can however, connect an external monitor to your laptop if it has the option to allow this feature. Refer to the instruction manual about how to turn on the option after the monitor is connected.
Jerry G.
Apr 11, 2008 | Toshiba Satellite A105 Notebook
Intermitently, my screen goes dark, but the
1.)It could be your video card
2.) Yes it is expensive for a laptop
3.)I would first check your screen setting for turning off display...
If you are using vista:
-Right click on your desktop then choose personalize
-Then click screensaver
-On bottom click on "change power settings..."
- On the left click on "choose when to turn off the display"
Your monitor can turn off without your computer being in sleep mode.
Dec 26, 2009 | Toshiba Satellite A105-S4334 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
LCD dark with white vertical line down it
It is the C-Board Panel Attached to the Display Panel And Is Integrated into the Screen .. You will need a screen replacement..
Your part is.... Toshiba Satellite A105 15.4" LCD Screen LTN154X3-L06
Feb 13, 2009 | Toshiba Satellite A105 Notebook
Toshiba A10 laptop screen
Have tried at all to change some of the basic settings on it? Or is it too hard to even read it to get to the settings? It could be something wrong with the LCD as well, in which case, there is not much you can do.
Nov 09, 2008 | Toshiba Satellite A105 Notebook
Funny screen and refusal to start
Sounds like a Video ram or system ram problem which is on the system board. Needs service.
Sep 22, 2008 | Toshiba Satellite A105 Notebook
Screen
ok man u have to do this go in a control pannal dubole click on adobe gamma set ur britness & conatrasst of your display & save
ithik your problem will be solved
Feb 27, 2008 | Toshiba Satellite A105 Notebook
Dark screen?
either it is set to use an external monitor, or the backlight or inverter is bad
Jan 11, 2008 | Toshiba Satellite A105 Notebook
Screen turns off
you have a bad inverter board, this feeds hi-voltage to the lamps that create the display. common for LCD screens
or the back light lamp.
hope this helps
thanks for your rating
Jan 07, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
215 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
