Question about HP Officejet 9110 All-In-One InkJet Printer
Attention Light My unit keeps recycling on/on etc. it does this everytime the attention light blinks. When I press ? for help it said there are no help features available. Bernie
I have two of these 9110s with this same problem?!?!?
Posted on Feb 15, 2008
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
The check engine light is on and everytime that i stop after a minute the light starts blinking and if i start to accelerate the car hesitates
When light blinks it mean need immediate attention, need to get diagnostic, should be easy find and hopefully fix.
Jan 11, 2010 | 2002 Ford Taurus
Changed ink: on and all the lights Attention! box keep flashing
The manual for a related printer suggests that you have a printer failure issue. If the paper lights are off, then it is a scanner failure. If the paper lights are also blinking, then it's a fatal error. Turn off the printer, unplug the unit and then wait one minute. Plug it back in and turn it on, if the lights keep blinking then call HP support. (If it is under warranty, then it may be worth fixing.)
If I misunderstood your post and the power light is steady but the other lights are blinking, then you may have the cover incorrectly positioned or something blocking the ink carriage. Open it up and check for anything out of place.
I hope this helps.
Nov 29, 2009 | HP Deskjet F4100 All-In-One InkJet Printer
Blinking red light no heat
It sounds like you are actually in lock out. Recycle is when during a call for heat, the flame goes out, the unit will try to restart itself. Hope this helps
Nov 10, 2009 | Water Heaters
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Lexmark X2350 printer problem
Usually the light blinks if you have started a print job and run out of paper...it's trying to get your attention to insert more paper before it can continue. Check and see whether there are any print jobs that weren't able to conclude and delete them. Go to 1) Start, 2) Control Panel, 3) Printers and Other Hardware, 4) View Installed Printers, 5) Lexmark 2300 Series. When you double click on the Lexmark Printer Symbol, it will open up a smaller window which will show you whether there are any print jobs that are waiting to print. If there are any, delete them. Hopefully this will solve your problem.
May 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
Philips magnavox, universal remote
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Apr 23, 2008 | Philips Magnavox MRU1400 Universal remote...
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
HP Officejet 9110 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
