Question about Audio Shelf Systems
Aiwa Stereo needs repairs
Aiwa Shelf System
3-disc CD changer - won't play- it tries to start but then doesn't
lights out on top front of unit
3 Suggested Answers
  • 8 Answers
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Posted on Mar 01, 2010
  • 643 Answers
SOURCE: I have an RCA Bookshelf
That problem is usually due to worn or stretched belts. Try replacing the belts or use a rejuvination liquid.
Posted on May 09, 2011
  • 66644 Answers
SOURCE: I have an old JVC
There are two possibilies for this faut. The first one is related with its Laser Pickup Unit, and the second one is related to its loading mechanism. If loading mechanism did not load disc properly to to the holding disc drive motor, disc wont play, and will be ejected as it enters into the system. i don't know, how old your system is, and how much it used so far. Anyway try first by inserting a head cleaning disc into the tray and play it for two of more time. if this does not help you try replacing the loading belt. You have to open your system to do this work. Loading belt can be located at the loading mechanism, fastened with its loading gear and loading motor. If this also does not help you, there is no other way than replacing the laser Picup Unit with same type and number. To repalce either belt or laser pickup unit, you have to open and disassemble the mechanism itsef to do the work. If you are not aware in electronics, and not so experienced in doing this type of work, get help from an other who knows these well. Most of the [90%] of components used in this section are made of high density plastic, and can be damged easly. If any wheel in loading gerar mechanis has broken teeth with it, also will poise this probelm. So it also should be checked.
Anyway you have to open and disassemble the mechanism as a whole. OK
Posted on May 25, 2011
0 characters
1 Points
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Shelf Systems
I have an old Aiwa stereo with a 5-CD changer. The remote control has RC-7AS05 on it. How can I program the CD player to play the CDs continuously?
Press the RANDOM/REPEAT button and watch the unit's display. There will be a graphic changing to show the different functions: Disc repeat....All Repeat.
Try out the different modes unit you find the one that plays all the discs in the carousel.
Sep 16, 2014 | Aiwa Audio Shelf Systems
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
Cd player on RCA R52653
overheating or lens dirty in unit buy lens cleaner cd to clean it
Jan 27, 2008 | RCA 100-Watt Stereo System With 5-CD...
How to unlock protected mode on a jvc 5 disc cd changer?
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
CD changer not playing CD's
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Jul 14, 2007 | Aiwa NSX-A505 CD Shelf System
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
Audio Shelf Systems Logo
425 people viewed this question
Top Audio Shelf Systems Experts
Are you an Audio Shelf System Expert? Answer questions, earn points and help others
