Question about Intel Compaq EVO D500 (RBMDTCPQP42400) PC Desktop
Compaq Evo D5 power light flashes red.
When I plug in the Evo the power light goes green for a second then starts flashing red. No fan or hard drive activity. Green lights on motherboard.
  • 121 Answers
Re: Compaq Evo D5 power light flashes red.
Try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Posted on Nov 13, 2007
0 characters
3 Points
Compaq evo 510 tower 1256 ram win 7 nvidia 6600 garapics card in AGP slot upon pressing power button goes green for about 1 sec and then nothing starts, power led just remains steady flashing red, some...
Could be the power supply. Try unplugging the internal hardisk power, the internal cd power and anything else that is connected internally apart from the motherboard power supply. This may reduce the load enough to allow the motherboard to be powered.
As power supplies age, internal electrolytic capacitors dry out and can no longer store sufficient charge to provide power. This usually affects the higher voltage rails more, so USB devices can still get power from the 5V rail.
Try a working power supply from another computer if you can or buy a replacement to fit your case.
Feb 22, 2011 | Compaq Evo D510 Minitower (Open Box)...
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
When I press the power switch, the green light comes on for about 2 seconds then it starts flashing red.
I'm afraid you need a new Power Supplies Unit. Just try an old trick first. Remove power cord from the back of PC. Press power button and keep it pressed for good 30 seconds. Then reconnect power cord and try to start as normal. If this don't work I'm afraid your PSU is dead. Good Luck
Apr 28, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Hi we have had a power spike and I have had to flatten and rebuild our Compaq EVO 310. This resulted in losing the drivers and then finding out that my partner does not have the original compaq disks for...
hello: the drivers you need can be download on hp /compaq site and reset the bios you can take battery out and the bios are back in standaard settings with startup you can make your own settings again
Nov 04, 2009 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
I get two green power lights
checking conection inside you PC, check if all cables are connected respectivley prior to HARD drive must be connected and powered up
Oct 06, 2009 | HP Compaq Evo W6000 PC Desktop
Red flashing lights, will not completely start up
Do you have a windows XP cd?
If so you can try booting from the cd and running recovery console.
from recovery console type chkdsk -r
This should repair any bad sectors on your drive, allowing the drive to boot
(this scan may take some time)
Jan 23, 2009 | Compaq Presario 5000 PC Desktop
Hard drive fan stop working computer stop, yes I have power but but,computer will not tyrn on PC will not power up when I woke up this morning and went to use it the green light on the front was flashing...
Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  1. Disconnect everything from the computer, including the power cord.
  2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
  5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
  6. Remove all attached devices except for keyboard, mouse, and monitor.
  7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
  8. Check the power switch:
    1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
      • If the button sticks, it should be replaced or serviced.
      • If the power button does not stick and appears to be functioning, continue using these steps.
    2. With the power cord disconnected, remove the case or side panel.
    3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
    5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
Oct 24, 2008 | Compaq Presario 5000 PC Desktop
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
Intel Compaq EVO D500 (RBMDTCPQP42400) PC Desktop Logo
2,334 people viewed this question
Top Intel PC Desktops Experts
Level 1 Expert
Michael Thomas
Michael Thomas
Are you an Intel PC Desktop Expert? Answer questions, earn points and help others
