Question about Ricoh Print Servers
Asistance Configuring ISC 2838 Photocopier
Help Please!:(
0 characters
1 Points
I need the software for this dvice
found this for you:
Configuring the PocketPro Print Server (Extended Systems) -
Apr 02, 2010 | Extended Systems PocketPro Print Server
How to connect a netfear router to a dell computer
I assume the Netgear is a wireless router and you want to connect to the router using a wireless connection.
Make sure the DELL computer wireless card is installed with the latest wireless card driver.
The Netgear router needs to be configured with the wireless settings ie SSID and encryption etc.
Next the wireless card needs to be configured with the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
Dec 23, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
I need instructions on resetting and configuring
Hello jvenette;
You can find detailed instructions on how to configure the server HERE.
Good Luck, and don't forget to leave a rating.
Thanks Mark
Apr 23, 2009 | Buffalo Technology LPV2-USB-TX1 Print...
USB printer HP 1020 Plus in DP-301U
Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
Cannot see WPSM54G wireless router after configuring it correctly.
It's pretty sad. This device doesn't support Mac and apparently it doesn't support Windows either! I expect a lot more from Linksys. It seems like this is a common problem yet they offer no clear solution on their web site. Do you think maybe Linksys is going out of business and isn't going to support their products anymore?
Apr 13, 2009 | Linksys WPSM54G Print Server
Configuring Printer
You posted this question THREE years ago.
Please provide more details.
Nov 13, 2007 | Print Servers
My Canon Imagerunner 2200 won't scan.
Sorry that was actually me...after i asked me to i did.
Okay, you need to download Canon Network scangear from the Canon website. then take your document...put it on the top feeder...turn you scanner up microsoft word 2003..insert, picture....from scanner or camera select network scangear....custom insert....then scan. The machine needs to be hooked up to a network...but note...a simple cross over cable or usb between pc and the photocopier will not work.
Oct 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Sharp Copy Machine
You don't say if you are using a server/client network or a peer-to-peer. Go to START >printers and Faxes >Add a printer >Next and select A Network printer select Connect to the printer and then enter the path to the printer eg \\server\printer name
Oct 01, 2007 | Print Servers
Photo copier
Please confirgue the print server properly. Assign a particular ip address to it if possible. Then install the photocopier driver in computer and add the network port ip eual to the ip of print server. if it does not work install the print server driver if comes with it as a printer and assign it a ip.
Jun 19, 2007 | Toshiba (GD-1010) for e-studio25S, 16S,...
First make sure the PS is hard wired to the router and you have all the wireless settings handy (including the SSID and Wireless Encryption). Then follow the step by step instructions in the file given below: Also, the printer with the ethernet cable seems to be a network printer. So, you need to do much to configure it, if its already configured; just connect it to one of the ethernet ports of the PS. Please revert back with any other queries.
Mar 14, 2007 | NetGear PS111W Print Server
Print Servers Logo
27 people viewed this question
Top Ricoh Print Servers Experts
old marine
old marine
Are you a Ricoh Print Server Expert? Answer questions, earn points and help others
