I have descaled my machine regularly, after the last descaling, it worked without issues for around 5 mugs. After this there was little flow through the shower screen/filter, removing the filter the water flowed freely, a cleaning of the screen only minimaly helped the flow.
Hi Colin:
There is a product called CLR that we use regularly on our coffe machine, kettle, metal coffee travel mugs, thermos etc. Could be you're in an area where your source water has a lot of mineral content. Do you have similar problems with other appliances? If so, the problem lies with the water supply and not the coffee machine.
Hope this helps.
Testimonial: "Ted Thanks for that, I also apologies as I forgot to mention I use filtered water only in the machine, a twin cartridge undersink type. Since using that filter, amazing how much cleaner all other appliances are. I am starting to think its the filter screen a replacement is not expensive & worht a try, as the machine is over 10 years olf may have had its day, though a great machine."
