If you have a Yahoo! account, you can change the appearance of your messages.
For example, you can change font color or size.
If the default font size for Yahoo! is too small or too large, there are two ways to change the font size.
You can change the font size while composing a message or you can change your settings and change the font size for all messages.
Click "New" to compose a message and click "Rich Text" beside the "Subject" line to show font options.
The appearance bar will open in your e-mail message; you can change font color and size here.
Highlight the text you want to change the font size. Change Font Size in a Yahoo! Mail Message
Look to the font options toolbar above the e-mail message and click the arrow beside "12," the default font size.
A drop-down list will open with the available font sizes.
Select a different font size from the drop-down list.
The font size of the selected text will change.
Change Font Size Permanently in Yahoo! Mail
Sign in to your Yahoo! Mail account and click "Options" located at the top, right corner of the window.
Select "More Options" from the drop-down list.
The Options page will open.
You can change your signature or message settings here. Select "General" from the list of options and look to the section marked "Plain text font."
Click the arrow beside "12," the default font size and select a different font size from the drop-down list.
Create Menu tab right click
in the top of screen (toolbar) you will see a number of toolbar options select
the menu bar
This will add to your
screen toolbar File Edit View Favorites Tools and Help
select the View from the drop down list will be a Zoom with percentages % and
text sizes largest to smallest and Full screen option Increase the Font Size in Email
Email font size is easily controlled while composing
messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size
8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text
are even more difficult to read.
There are a few ways to quickly change font size for ease of
reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font
size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100
percent.
Click "View" and cover "Zoom" to make a
larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll
the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is
"Medium," then click "Larger" or "Largest" to
make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the
wheel on the mouse.
The text will shrink as you roll in one direction, and grow
bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display
"100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text
size.
Click the "Print" button to view the
results on a hard copy.
To enlarge your font size: For XP OS: Right click on your desktop background, and select properties. A window will come up showing you the various system properties. At the top of this window click on appearance. At the bottom you would see the options to change the font size.
For Windows 7: Option 1: Click the start 'Windows button' at the bottom, the type either 'Appearance' OR 'Font size', then enter. You should be able to see the options for adjustment of font size. Option 2 Right click on your desktop background, then choose 'Personalization'. this should take you to a window where you can edit different appearance settings. At the bottom, you should see font size. You can also edit your themes as well. Most time themes, change everything about the system including font sizes. Thanks
For the earlier versions of Firefox, here are the instructions on how to increase your font size:
1)Click on View on the browser Menu Bar. 2)Highlight Text Size with your mouse and notice that you now have 3 choices that will allow you to increase or decrease text size. 3)Increase or Decrease your font size and you will see a change in text size on this web page. You can also hold down <CTRL> and type "+" or "-" to change the font size. 4)Select Normal or <CTRL> and "0" to return to the default text size.
For Firefox Version 4.0
There are 2 ways on how to change the font size of the page that you are viewing.
FIRST OPTION: Changing Font size through the TOOLS Menu:
1)Click on "Tools" on the browser Menu Bar, then click "Options". 2)You will be getting the Options Window Menu to change the settings of Firefox. In this case, since we would want to change the font size, you would need to click on the "Content" tab. 3)On the Content Tab Menu, under "Fonts & Color", you can change the size to whichever size you want. 4)After changing the size, click on the OK button and it should save the changes right away.
SECOND OPTION: Changing Font Size through the VIEW menu:
1)Click on "View" on the browser Menu Bar, then click "Zoom". (There should be a side option that will appear after you highlight Zoom.) Select or put a tick on "Zoom text only". 2)Click on "View" on the browser Menu Bar again, then click "Zoom". (There should be a side option that will appear after you highlight Zoom). This time, you can click on "Zoom In" or "Zoom Out" to play with the desired font size that you want on your browser page.
That simple! I hope this information helps you and if it does, please do not forget to rate me.
if your firmware supports that settings, you can always find it here..
1. press menu
2. select settings
3. select display and light
4. select font type
5. select from the given option and list
6. save and exit.
regards..
Assuming you have a MS Windows OS. There are a couple of ways to remedy this situation. Option one is to change the screen resolution by right clicking on the desktop screen and selecting Properties and then Settings. Change the Screen Resolution to something lower than the current setting. This will cause everything to enlarge on the screen. Option 2 is to just change the font size as the standard. Right click on the desktop screen and select Properties. Select Appearance and change the Font Size to Large Fonts or Extra Large Fonts. If you are trying to change the font in Internet Explorer then choose View/Text Size, select Larger or Largest. That will change only the fonts inside Internet Explorer.
I couldnt change mine in the options menu as jeckyb said, i just opened the message and you can control the font size with the volume button on the side of the phone! Found that out by mistake :) hope it helps
If you want to change the default HTML font size for outgoing e-mails:
Right click on the Desktop > Properties > Appearance.
Select "Message Box" in the Item drop down box > change the font.
If you want to change the default HTML font size for incoming e-mails (Using IE 5.5):
Open Internet Explorer > Tools > Internet Options > Accessibility.
Check Ignore font styles and Ignore font sizes.
Adjust the font style by editing the selections under the Fonts tab under Internet Options.
You can also create a style sheet (cascading style sheet) and use it as the default for all of your web pages. This option is accessible through the Tools > Internet Options > Accessibility menu.
