Question about ASUS K8V-MX Motherboard
Replacement HD Had to replace my old Maxtor HD as it failed - have a new Samsung 500 gb sata drive which runs at 3.0 gbps or can auto step down to 1.5gbps - the drive is not recognised in bios at all - my dvd drives on ide are recognised in bios - when I place Windows XP disc in dvd and install it runs Windows setup and seems to place some drivers etc into the machine - it then stops and the message "Windows cannot install please press F3 to restart" - when I do this and look in bios the Samsung HD is then seen - from this stage I have once sucessfully installed Windows but on powering down the machine it seems to lose the info on the HD and cannot again "see" the HD - does the K8V support the faster Samsung drives or do I need to change some settings in BIOS to let the machine see the HD - the original HD was a Maxtor HD also SATA - the only difference between it and the new one is speed and capacity - any ideas ? Steve
  • Anonymous Sep 27, 2008
    My old Maxtor 200GB HD failed I have purchased Western Digital 500GB HDD.
    The new HD is not recognised in the BIAS, old Maxtor is. Is there something I need to do to change the BIOS/settings to allow new HD to be recognised
  • Pras1982 Oct 04, 2008
    I have bought a 500 GB SATA HDD and the drive is not recognised in bios at all. The motherboard that I have is "K8V-MX".What could be the possible problem and how can I fix it?
    Any help would be greatly appreciated.
  • 85 Answers
Upgrade your bios
Posted on Nov 13, 2007
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
Please, i have two hard drives, the first one is maxtor 80 gb (which i want to make master),the other one is sata sumsung 750 gb (which i want to make salve), how could i get that done ?
That can be done from BIOS setings. First check that both the disks have been detected by the BIOS.
Usually, the hard disk at sata1 (1st sata connector on board is for master drive.
Secondly, look for the bootup option and choose maxtor as primary drive (to boot from it)
Hope this helps!. let me know about *********** board details also, if further any assistance is needed.
Nov 10, 2010 | Samsung SpinPoint T HD501LJ 500 GB SATA...
The Dell Dimension XPS GEN2 has support for both, IDE and SATA standards. Your Maxtor is SATA drive, you can use any SATA drive as replacement. You mentioned that the OS no longer find the drive, make sure that you load SATA drivers at your Windows XP reinstallation, maybe your old drive is not defective only not recognized in the installation process. You can download the floppy image with required drivers here, see SATA drivers section. When you start Windows installation, at the Windows Setup Screen you should see, at the bottom of the screen, a message saying "Press F6 if you need to install a third party SCSI or RAID driver." At that point press the F6 button and when the next screen appears press S key to specify an additional device. Select the drivers from the provided list(to load all drivers from the disk, beacuse I don't know which is yours as I don't know the content of the disk, repeat steps to specify additional device), after drivers load your hard drive should be recognized and you can continue installing the Windows XP operating system. Ignore these steps if your hard was already tested and confirmed that is defective. Good luck!
If this is the solution for your problem, please rate my post, otherwise give us more details.
Sep 26, 2010 | Dell Computers & Internet
500gb hard disk supported by intel D101GGC
This D101GGC Motherboard supports both IDE and SATA.
Mar 05, 2010 | Intel D101GGC Motherboard
Part No. 9W2874-582
Sata drives use both 5V and 12V power. The standard SATA connector found on most current power supplies carries both. If you're trying to rig up some temporary power just hit your local PC shop and ask for a Molex to Sata adapter that will connect your old power supply to the new drive or pickup a USB to SATA adapter kit as they usually have there own Sata capable power adapter.
Hope this helps FixYa,
Oct 21, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Can i use this maxtoe diamond max 21 500 gb drive for a c drive i am removing a 80 gig that is defective
If you mean remove your old 80 gb drive and replacing with the Maxtor 500 gb drive you should be able to. The Maxtor 21 series is equiped with SATA. Just make sure that your computer can run SATA. If not, I believe that there are adapters out there.
Oct 01, 2008 | Computers & Internet
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
New Maxtor 3200
Hi, This is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the PS3200 itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
ASUS K8V-MX Motherboard Logo
127 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
