I've had an issue with the water line in my side by side fridge (GSL22JFXJLB) for sometime now. The only way to keep the line from freezing was to have the small light located at the water dispenser on all the time. Recently that light has been burning out every two weeks from being left on all the time and the water line regardless of the light still freezes. The light had also melted some of the plastic casing inside of the dispenser housing. Here is what I've done to try and fix the problem: * Raising the temperature of the freezing to the warmest setting and just leaving it there. No Change. * Installing part WR49X10173 water tube heater. (Did not work at all) No Change. *Using a hair dryer to thaw out the water line. Will work for about 2 hours, then line freezes again. Is there any part that I can install into the freezer door/dispenser area that will help the water line stayed thawed so I can get filter water from my door?
The problem is the line is freezing up due to obstruction or blockage. which causes the water to back up and freeze, I have used a blow dryer, hot water, and a soft type long tiny tube or cord like material and even a coat hanger but be very careful, to get inside the line and unplug the obstruction or if u can remove the whole line and replace it? but may be very difficult. why was it pluged? some times pc's of plastic bags, old food particles, etc get into the line, doesnt take much
SOURCE: I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door. You will need to have the filter replaced and that should take care of the problem. But the filter should never have frozen in the 1st place. You will need to call a qualified LG technician to see what's going on inside the refrigerator.
SOURCE: Freezer melts then freezes again
hi thanks for the question is this a new fridge . if it is the fridge does shut down to enable the freezer to thaw. if it did not do that do that the freezer would ice up . not cooling the fridge part thanks for the question
SOURCE: Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
SOURCE: Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
SOURCE: No water from the dispenser!!!
Don't keep using a hair dryer ! Order the dispensor heater kit , pt # WR49X10173 . It comes with complete instructions for installation , so you can spend more time with the family .
