Cars & Trucks Logo
J
JUVENIL SAGOCSOC Posted on Mar 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i fixed the Mitsubishi Montero 2000, when i run the engine in few minutes the engine will stop and A/T TEMP. appear on the dash board and won't start again.
Geof
Level 2:
Sergeant:
  • Expert 120 Answers
  • Posted on Mar 11, 2015
Geof
Expert
Level 2:
Sergeant:
Answers
120
Questions
Helped
21277
Points
910
A/T Temp Light, that is it warning you that your trans is overheating.
temp sensor is bad, your transmission cooler is bad, I would have it fixed. don't want to have to put a new tranny in there.
Testimonial: "Thank for the wonderful answer....i hope i can ask more question."
Ecu location on a 2000 Mitsubishi Montero sport
ecm-undefined-undefined-0.jpg The engine control module appears to be, passenger side, under the dash on the kick panel. If we're talking about the same thing. good luck
My 2002 Mitsubishi Montero will shake real bad at about 40mph/2000rpm's, once your over that speed it will stop. It does not do this when you first start driving and the engine is cold but once it warms up...
This sounds like a wheel balance problem. A local tyre depot will fix in minutes. Try this first before you pay for expensive suspension and steering fixes.
1998 Mitsubishi Montero sport emergency brake is OFF but there is the red brake warning on the dash board. How to fix. Thanks
Hi, please check your brake fluid reservoir. Please see my tip at http://www.fixya.com/cars/r6004281-brake_indicator_light_stays . These are genericinstructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
10helpful
4answers
2001 Mitsubishi Montero Limited. 122k miles.
2003 Mitsubishi Montero Limited. 97k miles. Temp gauge is erratic when actual temp is normal. How do I fix this?
2helpful
Tapping sound on Mitsubishi Montero 2000
nothing to much to worry about.this is quite normal to many ingines. it may be gum build up, making a valve or piston ring stick. inexpensive first thing to try, run some engine restorer in the oil, one that say s it removes cabon and gum from engine, like wynns.follow instructions on can. you will see all the crud come out of the oil when you drain it.
4answers
The temp shot up in our 2000 Montero. Pulled over and discovered the upper radiator hose has come off. Let it cool, reattached, checked coolant/water and started to drive. in a few minutes, a knocking...
you may have overheated engine and not known it because if no water is present on temp sensor it will not show hot sounds like overheating of bearings in lower end possibly major engine repair may be needed
2002 Montero limited overheats can't find problem.
Sounds like the thermastat is stuck closed. The water in the engine would get very hot while the radiator remains cool.Don't drive the car this way as serious engine damage will occur.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
