Samsung Galaxy Centura Android Prepaid Phone with 600 Minutes and Triple Minutes Tracfone Logo
d
domenick di clemente Posted on Mar 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to call internazional call. I dial 1887063839 1 011 country code city code phone number. the booklet tells me I can make international call at no additional cost
Clive Gray
Level 3:
Genius:
  • Samsung Master 1,479 Answers
  • Posted on Mar 11, 2015
Clive Gray
Samsung Master
Level 3:
Genius:
Answers
1479
Questions
Helped
291305
Points
4728
You need to go to wherever you prepay your phone so they can sort it. a lot of prepay phones cannot call freephone numbers or charge premium rates for them.
I am dialing my niece in Trinidad but i am getting busy signals 2 days now
Where are you dialing from/ what country are you in.
All countries have this sequence of numbers to call another country;
IDD COUNTRY CODE CITY CODE PHONE NUMBER Dialing Instructions
  1. Dial the International Direct Dialing (IDD) number. Countries have different numbers, or may have more than one IDD, depending on the carrier or type of service.
  2. Dial the Country Code. In some cases, the country code is shared among countries. For example, the United States, Canada, and much of the Caribbean and Guam use country code 1
  3. Dial the city/area code (if any) for the number you are dialing. Smaller countries may not use city codes or area codes, while larger countries have hundreds of them.
  4. Dial the phone number you are calling.
How To Dial Internationally
Where can I find a + symbol on the dial face. I have tried to dial international calls with out the plus symbol and it wont connect me
You don't need a + symbol to dial international.
  1. Step 1: Dial International Call Prefix.
  2. Step 2: Dial Country Code.
  3. Step 3: Dial City Code (area code)
  4. Step 4: Dial Local Number. So let's say you are trying to call a local number in Sao Paulo, Brazil from Miami, Florida, USA. ...
  5. 011 55 11 2345678.
1helpful
4answers
How do I call international
You need to put in the country code first before you can call the number.
I need to the Country Code for the US when making a call home from another country. I travel quite a bit to France but I am always with my family that have me in their speed dial. Thank you.
To call United States you have to dial 00 + 1 + City Area Code + Number you wish to call.
You have to get the city code your self because you did not tell me the city you are calling.
Thanks for contacting FIXYA.
What is the dial code for international calls from Hong Kong
STEP 1: FIRST YOU HAVE TO DECIDE WHERE ARE CALLING? I MEAN IN WHICH COUNTRY THEN IF YOU HAVE A PHONE DIRECTORY FIND THE CODE FOR THAT COUNTRY OR FIND IT FROM INTERNET SUCH FOR DAILING TO PAKISTAN WE HAVE TO DIAL 92 FIRST
STEP 2: FIND THE CODE OF THE CITY IN THAT COUNTRY TO WHICH YOU ARE GOING TO MAKE CALL
STEP 3: DIAL THE NUMBER AFTER DAILING COUNTRY CODE+CITY CODE(AREA CODE OF THAT CITY)
IF STILL UNSURE WHAT TO DO VISIT
http://timeanddate.com/worldclock/dialing.html?p2=102
BUT IF TO WANT TO CALL HONGKONG THEN
To call Hong Kong you will need to dial:
img_generator.php?text=fyju%21dpvousz%21dpef%21,%21963&ft=luximri&fs=16&fa=0&xpad=4&ypad=4&tr=0&tg=0&tb=0&br=255&bg=255&bb=255img_generator.php?text=%21,%21uif%21ovncfs&ft=luximri&fs=16&fa=0&xpad=4&ypad=4&tr=0&tg=0&tb=0&br=255&bg=255&bb=255
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
2answers
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
L220 Cannon Fax tx function was not completed
It's possible you're not dialing the country's calling code or not dialing the correct sequence for international calling. To place a call out of the U.S. dial: "011 - country code - city code - number" The country code for Poland is 48. The link below contains the city codes for Poland which you may not have. Best of luck and I hope this solves your problem. Thank you for using Fixya and please remember to return to rate this answer.
International Calling Codes
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
