Question about TruTech PVS2119 19 in. LCD Television
Dishnetwork Is there anyway to program a Dishnetwork DVR remote to work with this tv
Re: Dishnetwork
Nope sorry
doesn't work for some reason trutech which is made by daewoo uses a nasty form of remote controll unless you are willing to spend 99.99 for a logitech remote controll there isn't jack you can do.
Posted on Nov 21, 2007
0 characters
3 Points
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I have an akai 21' tv. I cannot program my dish network remote to work with the tv. None of their codes work. Do you have codes I might try
Hi my name is Mike Houston of DISH Network and I see youwant to program you're Akai TV to our DISH Network remote. There are some easysteps to allow setup to your TV and I will send the link, select the receiver you have and it will take you to a help page. I willsend a link for a Power Scan and the power scan will find the remote code foryou; you have any questions or concerns please e-mail me at
Jul 29, 2011 | Akai LCT3285TA 32 in. LCD Television
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
Dish Network 625 DVR remote code needed for Dynex DX-L22-10A
Hello, you may have already gotten this resolved, but if not, here are some simple steps to help you out. Just follow the link below, it will walk you through the steps to program that remote to your tv. I hope this helps.
Becki Barned
DISH Network Customer Service
Oct 14, 2010 | Dynex DX-L22-10A 22 in. LCD TV
Need remote code for dish network remote to control philips tv want dvr and tv to work off the dish remote
If you have not found the codes yet, follow the link below. The link will walk you through the steps to program the remote to the tv. They are simple steps.
If the codes do not work, try this link for a power scan, which will scan the tv for the correct code.
Becki Barned
Aug 04, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
DishNetwork Remote won't program to control ilo EDTV
Hi, Hope this helps. I used code 720 for my dish remote to remote my ilo tv. It works great. Hope it works for you. Bob
Jan 11, 2009 | iLO 2600 Television
Remote code
I had the same problem with a Viewsonic N3735W LCD TV and Comcast Customer DVR 3 Device remote. I contacted Viewsonic and they gave me 11454 which works.
Dec 19, 2008 | ViewSonic N3735W 37 in. LCD TV
Remote code
Have you tried the website of DISHNETWORK.COM yet?
Jul 23, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Universal TV remote control
Target sells a GE Universal Remote Control, 5 Device with learning feature. I can't say if it works with your Verizon DVR, but its code for the Akai LCT3285TA is 1139. If you have the Verizon's remote, you should be able to use the learning function to make the GE control it - that's if the GE doesn't have a built in code that will work for this DVR.
Apr 26, 2008 | Akai LCT3285TA 32 in. LCD Television
"No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Feb 26, 2007 | iLO 2600 Television
TruTech PVS2119 19 in. LCD Television Logo
99 people viewed this question
Top TruTech Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a TruTech Flat Panel Television Expert? Answer questions, earn points and help others
