Question about Brother IntelliFax-4100e Fax
Toner cartridge message
Display shows Toner Low message. This machine is running as a stand alone. It is 5 weeks old and there is no way they could have faxed or received 3,000 docs. That is the life of the cartridge supplied correct? Any assistance would be most welcome...Have a nice day.
  • Koivu Nov 13, 2007
    Thanks in advance - It turns out they do use 3,000 sheets in about 4 weeks of faxes. So I purchased the 460 toner cartridge.
    Genius:
  • 2,120 Answers
Nearly all Manufacturers now only give you "starter cartridges" in new machines.
Posted on Sep 26, 2008
Do the tone cartridge time out?
Hi, if the above suggestions dont help it may be out of toner. according to your dates and numbers. average 17.5 copies per day. you purchased it approx..300 days ago. = 5,250 total copies !?
Jun 06, 2014 | Brother MFC7360N AllInOne Laser Printer
Does anyone know how to reset the toner levels in an HL3040, i have put new colour toners in and each is still showing empty
Hey, I've just figured this out myself. Here is the procedure:
1. Open the front cover that gives you access to the toners. 2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen. 3. Using the "+" and "-" buttons select the toner you want to reset. 4. Press the "Ok" button. 5. It will display "Ok?" and hit the "Ok" button again to reset the toner. 6. Close the lid.
All done!
Regards, Michael Pasqualone TotalServe Solutions
Nov 01, 2010 | Brother HL3040CN Laser Printer
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
3 month old machine, low print usage, showed "Replace Toner". Replaced with Samsung cartridge but still showing Toner Empty message. Replaced with another new Samsung toner, but message will not go away....
you need to reset printer thorught software
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 02, 2009 | Samsung SCX-4300 Monochrome Laser...
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Brother IntelliFax-4100e Fax Logo
166 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
