KitchenAid Kitchen Aid KHWS01PWH WASHER GLOBAL HORIZONTAL AXIS BRAND IN STOCK
Problem for KitchenAid Kitchen Aid KHWS01PWH WASHER GLOBAL HORIZONTAL...
How Old is Kitchen Aid Washer model#KAWE577BWH1
By smikky on Jul 09, 2009
How Old is Kitchen Aid Washer model#KAWE577BWH1 Serial#CE0804943?
Spin Cycle not working
Best Solution
posted on Jul 16, 2009
Very Helpful)
dbh41454
Rank: Apprentice
Rating: 100%, 1 votes
Excellent reply!. I had same problem. Used to just drop the lid a few times and the washer would restart. Today it did not. I called KitchenAid. Some young lady said it was the pump motor. She recommended that I call for service. By the time someone comes out and replaces a motor it will cost more than a new washer! Found your response. Thanks for your help!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 09, 2009
Very Helpful)
jsrock516
Rank: Guru  KitchenAid Washers & Dryers  Expert
Rating: 96%, 7007 votes
Your washer was manufactured in 1995 and is made by Whirlpool. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Was this helpful?
Yes
No
Popular Solutions for KitchenAid Kitchen Aid
Questions and Unsolved Problems for KitchenAid Kitchen Aid
Do you recommend KitchenAid Kitchen Aid KHWS01PWH WASHER GLOBAL HORIZONTAL AXIS BRAND IN STOCK?
Answer
Answer
when I turn on the wash machine there is a humming noise coming from the motor, wash machine is... (More)
Answer
how do you remove the coupling from a kitchen aid washing machine?
Answer
washing machine will not agitate and will not spin. It will fill and motor is running and there are... (More)
Answer
My Kitchen Aid Quiet Care Super Capacity Plus washer won't dispense fabric softener. I've tried to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
