Question about PC Desktops
No power to dell opiplex gx1
Their is power going in to the computer via lead but i cant get it to turn on tried taken battery out and switch on not working still if i can get my pc to turn on that would be great
  • 121 Answers
Re: no power to dell opiplex gx1
Try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
ps: if the mainboard bottom was in touch with anything metal from the case otherwise it will get damaged.
Posted on Nov 13, 2007
0 characters
3 Points
My computer wont turn on
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope it helps
Apr 17, 2012 | Dell Dimension E520 PC Desktop
My dell optiplex gx1 cant read both hdd and cd rom pleas help me
Go on your desktop and right-click on the "My computer" icon and go to its properties
Then go to "Hardware" Tab and then go to "Device Manager"
In the Device manager, notice any yellow question mark or exclamation mark especially on the CD Drive. Right-click on it and choose update driver. The the driver installation wizard will take you through the process. When complete, restart the computer and try if its working. Do the same on the USB component in the device manager. This should solve you out of that, It means the CD Rom drivers as well as the USB are corrupt or missing...
If this does not work then consider using any software that scans your computer and reveals to you the drivers missing on it.
If this does not work, i think you just have to re-install your Operating system
Aug 22, 2011 | Dell OptiPlex GX1 PC Desktop
Dell Optiplex GX1 not recognizing all hard drives.
If you connect the drives using one single ribbon cable with two connectors on it then you need to set the drives to Master/Slave using the jumpers on the drives. Master being your OS drive.
If you are running a very old Operating System, make sure it can support a 20GB drive.
Jan 07, 2010 | Dell OptiPlex GX1 PC Desktop
I mistakingly switch the voltage to 110v instead 230V
You are going to have to replace it....obviously. Here are some places that popped as having the supply you need. I have never used any of them personally.
Dell Optiplex Gx1 Gx110 145w Desktop Power Supply 5554t
$14.99 used - eBay Dell 11VTW Optiplex GX110 SFF 110W Power Supply (See 1728P)
$35.00 refurbished - Used-pcs.comNEW Dell Dimension XPS OptiPlex Power Supply, 200W, Dell 824KH
$19.97 new - TXcess Surplus
Oct 07, 2009 | Dell OptiPlex GX110 PC Desktop
My Dell Optiplex GX1 will not boot. The Monitor shows no signal.
check whether ur ram is working or not. remove the cpu side door and remove the ram from the ram slot and clean it using a eraser gently and fix again it back and power ur pc on and check it
Feb 23, 2009 | Dell OptiPlex GX1 PC Desktop
Motherboard having a system password , idonot know what is its pa
Open the case and look for a jumper switch (usually blue or black color) labeled CLRTC or CRL. A jumper switch is a small connector connecting two pins on the motherboard. Same like the one in CD ROM drive or hard drive for selecting master or slave.
If you find it, unplug the power cable, remove the jumper. Wait 10 - 15 seconds, then put it back. Plug the power cable and try power up your computer.
Dec 25, 2008 | Dell Dimension 2400 PC Desktop
Drivers for ethernet controller and USB controller
go to the Dell support site and enter in your Service Tag # -- this should give you access to all the drivers that originally came with computer,
Jun 30, 2008 | Dell OptiPlex GX260 PC Desktop
Black Screen
check your video card and try to go to windows recovery console or advance boot up options it seems the monitor self test passes!! if your video card is fine then its a video driver issue.
May 15, 2008 | Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB...
PC Desktops Logo
117 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
