Question about Canon Pixma iP6600D InkJet Photo Printer
Error 6000 This printer has been working great, but stopped in the middle of printing a photo with an Error 6000 message. Best Buy states the printer is fried and will cost more to repair than to purchase a new one. I have used the printer very little and am obviously frustrated that it has failed after owning a little over a year. Can you help?
Re: Error 6000 - Canon Pixma iP6600D InkJet Photo Printer Printers & Copiers
Error 6000 means jam paper
Posted on Jan 25, 2008
  • 4,402 Answers
Re: Error 6000
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Posted on Jan 08, 2008
0 characters
3 Points
In the middle of printing out 8x10 photos, it stopped picking up the photo paper. Makes a grinding sound twice, then beeps error.
Hello Lynell,
Unfortunately, printers only last for about 3 years or up to 5 years if it's a more expensive model. Try a Google search or YouTube search for DIY repairs on the model you own. You may find some helpful information on how to repair your printer. Or, it may be time to get a new one. If that's the case, see if Best Buy will give you a trade in price on something new. Best of luck!
Feb 25, 2015 | Printers & Copiers
Error: 6000
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Canon Pixma iP2700 InkJet Photo Printer
Windows 7 home edition HP Deskjet D1660 Problem: Printer will print a full page document, but stops in the middle of printing a full page photo. I just installed this printer, i bought it yesterday....
I have the same problem with my printer. I don't use it too often, but when I attempt to print more than a few pages in succession, I run into this issue. Normally, the first few pages will print off just fine. Then, suddenly, it will print half of a page and simply stop in the middle. Pressing the power button gets the printer to release the stuck sheet of paper, but then it will not allow me to resume or delete what is in the print queue. I generally have to reboot my computer after unplugging the printer and plugging it back in before I can resume printing. It does this nearly every time with no known error messages. I don't understand why it happens.
Sep 04, 2010 | HP Printers & Copiers
Error code 6000 on canon pixma mp210 stops me from printing
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Mar 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson Photo Stylus 950 not functioning
when ever you want to refill ink make sure, that the ink you refill decompressed for about 30min before you fix it into the printer.
Another thing is that you uninstall the software of the printer and reinstall again, and check the power supply of the printer is working perfectly.
Dec 03, 2008 | Epson RX620 All-In-One InkJet Photo...
HP psc 1300 printer
I had to turn off my computer, unplug the printer power cord and computer cord. I restarted the computer and pluged in both cords to the printer and it worked.
Oct 07, 2008 | Printers & Copiers
in my r300 epson printer general error appear . How can i remove or clear this error from my printer lcd
Feb 01, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fried Epson Stylus Photo 2200 by plugging into 220 volts in Europe
Buy a new/refurbished printer from They are cheap, come with a 1 year exchange warranty and do great prints. Prices for All In Ones start at $36USD, the ink costs more. I check Epson's voltage and I only found 115V AC, so you must use a transformer. I would also get a CISS and Waste Ink Container at the following:
Saves tons of money and never change or buy another cartridge.
Dec 18, 2007 | Epson Stylus Photo RX700 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
201 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
