Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
Can't access AV Channel on Sony KV-C27TD
By switch2k7 on Nov 13, 2007
Recently got an old Sony Trinitron TV. There were no RCA inputs in the back so I had to get a Scart to RCA converter to be able to hook up my DVD player / Xbox. Unfortunately I can't switch over to an AV channel.
Don't have the original remote but I do have an Universal One for All Remote. The remote works well and controls basic functions (power, changing channels, volume, etc) although this won't switch to the AV channel when the button on the remote is pressed. I've attempted to tune the AV channel into another numbered channel using the tuning buttons on the base of the TV but I haven't had any luck.
Has anyone had experience with this model or issue?
Solution #1
posted on Nov 13, 2007
Somewhat Helpful)
Moryath
Rank: Master
Rating: 85%, 43 votes
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Was this helpful?
Yes
No
Solution #2
posted on Jul 12, 2009
Not Rated)
dangaz
Rank: Apprentice
Rating: 0%, 0 votes
Moryath:
Actually, SCART is a european av connector, which on it's 21 pins can carry RGB, Y-Pb-Pr, composite and S-Video systems through it, and control signals that can turn some equipment on and off, and switch aspect ratio modes (various voltages on pin 8 perform this function), it is up to the manufacturer which pins to actually connect internally and most small tvs only use the composite video, and left and right audio pins.
What switch2k7 has takes the video plug of the composite cable, and maps it to pin 20 (pin 18 earth), and left/right audio plugs to pins 2 and 6 (pin 4 shared earth)
An RF modulator is a completely different bird, but had this been what switch2k7 had been talking about your advice would be correct.
http://en.wikipedia.org/wiki/SCART
switch2k7: It may be your universal remote not knowing the right code for the av channel, proper replacement remotes can be ordered online.
http://www.avukltd.com/remotecontrolsearch.php?item_id=538163&action=send_details
I'm sure with your question being there so long you probably don't care anymore, but there could be someone else out there who needs the info.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
horizontal lines in the screen with a samsung 42" tv
Answer
My Evesham TV V32ECCB has lost power all together. Any known problems & solutions
Answer
i have a 50" dlp it wont turn on, it sems like its about to go on but shuts off after about a... (More)
Answer
my remote ctrl stopped working. Batteries replaced, still nothing. It works from the buttons on the... (More)
Answer
graph like markings on screen back ground when switched on.sound and picture ok
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Standard Televisions:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
