White line in the across the screen
I have Grundig T63-640 TV
i've got a white line in the middle of the screen
i found information said i have to replace the capacitor number 468 which is 15UF 25V
is it true
  • Subhash K Feb 28, 2008
    I think the problem would be with the Picture Tube in my TV. I could see the normal screen there is a white line in the accross the Screen. plz help with this and also I would like to know about the price of the Picture tube
  • 372 Answers
The chassis number would be helpfull it will be on the back of set may start CUC
Posted on Nov 15, 2007
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
White line only, has sound, may be 14 yrs old.
If there is a white line across the screen, the vertical output section of your TV is faulty. If the line is vertical at the middle of the screen, horizontal deflection yoke doesn't get sweep signal. You haven't mentioned about the full mode number of your RCA TV. Therefore I can only give you this much hint. OK.
Mar 06, 2011 | RCA Televison & Video
A line has appeared across the bottom of the screen and also along the middle. the bottom line is white/ and the middle line is mainly green
If your TV is still under guarantee then change it asap, if not you have a problem, the panel has failed, in very rare cases the lines will disappear when the set is at its maximum operating temperature, that said it will never be 100% again, sorry
Apr 19, 2010 | Grundig GU26DVD 26 in. LCD TV/DVD Combo
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Audio ok, no video
I’ve never seen this kind of video output caused by a bad video cable or bad FL inverter board. it was fixed after I replaced the monitor
Apr 03, 2009 | LG Flatron F700B 17" CRT Monitor
TV Screen
im pretty sure you cant fix that you probably need to buy a new one.. i know that because my somputer has a white line that runs right down that middle, not all the time but sometimes. my father looked into fixing it and he found out that you have to buy a brand new screen or tower or something like that.
Dec 31, 2007 | JVC AV-32020 32" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
