Motorola Mobility ELECTRIFY M XT901 4G LTE SMARTPHONE - US CELLULAR Logo
A
Anonymous Posted on Mar 11, 2015
Electrify M: how do i fix a depleted battery?
When i plug my phone into the charger the notification light comes on then turns off. the phone's battery meter dosen't show and the phone will not turn on
  • Official Brand Answer 1,623 Answers
  • Posted on Mar 11, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350707
Points
5677
Charge it for an hour. Then it should turn on.
Mark
Motorola Support
My phone will not turn on
Charge it. Once the battery is depleted, if you plug the phone into a charger, the phone will for some time refuse to show any life even while plugged into a charger. If you have some sort of fast charger, it may come to life almost immediately. Otherwise, you are in for a bit of a wait. How long? -An eternity if you need to make an immediate call or receive on. Otherwise, my "guess" is that it will at least work briefly within a half hour.
Make sure your charger IS plugged into the wall to a working wall socket.
If you accidentally completely powered it down, simply power it up. Seems obvious but you have to eliminate the possibility.
There is always a possibility that the battery is not holding a charge. Ask yourself how old is the battery.
Jul 31, 2017 • Cell Phones
tip
Phone won't charge at all? No lights? Fix it here!
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Oct 02, 2007 • Dopod 838 Smartphone
I have a problem getting my phone on. i have a motorola electricify. it wont turn on even when i try to reset it hold the volume down button. it wont do a thing. it wont charge. everytime i plug the c
Kyle
let it set on the charger for a couple hours without attempting to turn it on. See if the battery icon appears.
If that doesn't work you can try MOTOROLA ELECTRIFY Master Reset Factory Data Reset
Mark
Motorola Support
Why won't My motorola electrify M XT-901 turn on?
I would try:
1) Remove the battery, carefully jumper contacts phone power by some metal object (screwdriver, knife ...);
2) If it doesn't turn on, try to charge the battery external battery charger.
Motorola electrify m wont turn on and had no lights when on charger
In the unlikely event that your phone stops responding to touches and key presses, try a forced reboot-press and
hold both the Power and Volume Down keys for about 15 seconds. If necessary, hold the Power key to turn your
phone back on
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 • Cell Phones
4helpful
2answers
How to be turn on Display light Nokia E61i Mobile????
Go into settings and open phone settings and then display settings
SANYO MM-5600
If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the back light will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone, Sometimes the ones that come with the phone can ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway. Use the charger that came with your phone, the voltage/amps are not always just right if using a radio shack special.
5answers
MDA (i really need this phone to work, my fav. phone)
The freezer thing was a stupid idea. Maybe your charger is not an original charger? or if it is the charger port could be loose.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
