SOURCE: M-Audio FireWire 410 External Distorted Playback...
You might need to Increase the Latency In the FirePod Control panel to a higher/greater value. Try 25.0 ms first just to see if this solution works for you. Then go down from there until you find the line between clean and distortion.
SOURCE: m-audio firewire 410 on macbook
Use a 'Y' splitter. Usually from balanced to unbalanced. Also try looking at your device's control panel and see if you can change the channel options from mono to stereo. Beta drivers are for testing purposes, so try the signed driver also.
SOURCE: UNABLE TO INSTALL FIREWIRE 410????
I got the same problem, but cannt find out or google it how to reset the device, found just some scripts, cannt use that, do you have some help?
THANKS
