Vsd fault 2 is a current imbalance. Check your current readings and compare them to those on the intellysis display they should match, also check for a imbalance in amps. After that it gets more complicated using board diagnostics etc
these compressors are costly even the parts to maintain.I would first check if you cooling fan for the vsd drive is working which is located in the electrical panel of the compressor.A failing fan or one that has failed would cause this fault
Vsd 1 fault is over current, check if motor turns ok, if this is ok it could be a number of issues that will need to be diagnosed by an Ingersoll Rand technician.
Vsd 23 is a motor under speed problem. Check motor turnes ok, if not it could be a number if faults including the hall effect sensor that detect motor speed, you will need to call a Ingersoll Rand technicion in to do a 348 diagnostic test.
