Question about Philips WACS700 Shelf System
REMOTE NOT OPERATING CORRECTLY
I can only get the standby button on the main remote for the Wacs700 to work... showing connecting to center and the x flashing in the top right hand corner.
  • Philsbird Dec 02, 2007
    Will turn centre on and off, but will not do anything else
    Displays "Connecting to Centre" and a flashing cross appears in top right hand corner.
    Replaced batteries on remote
  • barsue Jan 06, 2008
    i brought my wacs 7000 in november 15. 07. 2 way remote will only switch the station on and off.has a "x"in the right hand corner of the display.unit works o.k.manually .have reset the station.will work o.k. with 1 way remote.have changed battries of 2 way remote.worked o.k.at first,then for no apparent reason stopped working properly
I had the same problem.i took the remote to the store where i purchased the system,and it worked perfectly on a display model .i realised then that it was sitting under my television at home.i moved the unit to another location away from the tele and the remote worked correctly.give it a try."barsue"
Posted on Jan 13, 2008
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
My 16" led lcd dvd combo TVs does not turn on. The standby light indication is on but when I push the standby button on the TVs unit nothing happens. As I have lost the controller and un able to switc
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 05, 2015 | Televison & Video
Standby light does not turn on
Sounds like a main board [motheboard] fault. Contact service center.
Aug 01, 2013 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
The TV worked fine on Sunday evening, turned it off the normal way when went to bed. Came down to turn on in the morning and only the red light comes on indicating standby mode. I have unplugged...
There seem to be a problem that is why the television is not coming up and stays stuck on standby mode.
First try to turn on the television using the remote of the television and ensure that the battery of the remote is properly working, you can as well try to push the channel button on the television if the remote does not work.
If it does not come up both by using the remote and pushing the channel button, then it means it is a hardware problem, and that is from inside the unit of the television. Since the standby light comes up, it simply means power is reaching the main panel of the television.
This mainly used to be caused by a faulty or bad capacitor on either the main panel or the power panel of the television.
To check and fix, follow the steps below:
Dec 07, 2010 | Insignia NS-LTDVD19-09 LCD TV
Streamiun Wac700 CENTER says can't connect to center...help!
put units side by side and switch them both off. Plug in main unit, and using menu resort factory settings, then when it reboots, select language, and leave it there. Then connect the smaller unit and do the same thing (restore settings), they should then find each other.
Apr 27, 2009 | Philips WACS700 Shelf System
Wacs700 connection to my pc via wireless
use http://www.lucia-mathias.com/wacs/, it will find music center as long as security settings for wireless are correct, if never connected to a pc use the original pilips disc to set up first
Aug 13, 2008 | Philips WACS700 Shelf System
WAC700 Wireless music center
This can be caused by either corrupt firmware, or bad connection between the front panel and main unit.
The firmware can be restored as follows:
Unpluck the unit from the mains.
Press and hold [STOP] & [SOURCE]
Plug unit into mains.
Continue to hold the two buttons until the recovery message appears on screen.
If the progress bar doesn't move at all within 5 minutes, then this is not the problem.
______________________________________________________
This problem can also be caused by the ribbon cable connection between the front panel and the main unit. Sometimes the problem can be cured by disconnecting both ends of the cable.
The firmware should still be ok in this case.
There are multiple processors in the WACS700 unit, and the problem occurs when they can't talk to each other.
An authorised service agent should be able to sort the problem with a replacement cable.
Mar 15, 2008 | Philips WACS700 Shelf System
Wacs700
Don't use the remote control. Use the buttons on the unit. You should be able to get into Station Management then.
Nov 11, 2007 | Philips WACS700 Shelf System
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Philips WACS700 Shelf System Logo
60 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
