Question about HP Compaq nc6320 Notebook
When I power it I get a black screen. The mute led on the keyboard is ON.
  • Ngari Nov 19, 2007
    Thanks Jobbe. I've followed your suggestion. But I still have the same incident. Please advise with the next step.
  • supermule Dec 10, 2007
    Same problem, no HDD activity, No BIOS message, only the Mute lindicator and power-on indicator is ON with some DVD ROM activity in the beginning.
Remove you battery and disconnect power supply. Press power on a couple of times. reconnect power supply but leave out battery. Press power on. Hopefully machine will boot now.
Posted on Nov 19, 2007
  • weezel Apr 19, 2011
    I have a similar issue. I found removing the Ram allows me to get in. I have tried a few other sticks of RAM an receive the Blank screen whenever any RAM is in. Luckily there is 512 built in.
  • t3track3 May 11, 2011
    it didnt work for me do you have any suggestions?
    please help
How to switch off the right most LED right of HP 505130-371 keyboard
what PC, the pc has a name and model number?
and the light has a name.
that number decodes to USB Desktop keyboard. COMPAQ
my guess is that is the power lamp , if you dont like power on
then use black paint or electricians tape to black it out.
start the computer, in windows press F1
in the box type keyboard.
numlock , caps lock, USB poweroK
somethiing like this is the LED order top right.
Jun 28, 2017 | HP Computers & Internet
Nx7400 black screen
back light problem
check led and inverter
Feb 22, 2014 | HP Compaq nx7400 Notebook
I have laptop by fujitsi it runs normally but the screen is completely black
When the display shows the following cases, that need to be replaced a LCD Inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Aug 16, 2013 | Fujitsu Siemens KBPC SX Keyboard
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
Black screen on hp touchsmart 310-1020
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 11, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Hp pavilion black video
This is a RAM problem. It can happen when you open your computer and tamper with it or just mishandling such as dropping laptop
May 26, 2012 | HP Pavilion Computers & Internet
When i switched on my dell laptop (latitude E5500) today, it just displayed a black screen . the tiny power lights on the keyboard are blue which means the laptop is working fine ,just the screen goes...
hold the Fn Key while powering on, this will enable the PSA diagnostics, if you get any video and or the diags function then that should give you an indication of the problem.
If you only get LED lock light indications, then check here:
Jun 13, 2011 | Dell Latitude E5500 Laptop
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
No display
Are all the other LED Blinking. Fans revolving, etc but no power at the keyboard or mouse(if optical), then the problem is with the keyboard or one the pins of its PS2 connector might be bent. Try a different keyboard and see if the PC boots up.............sodeep
Mar 31, 2009 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
HP Compaq nc6320 Notebook Logo
251 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
