I can´t play xbox 360. The xbox says change to 60 hz mode,and when i do, the picture gets messed up and won´t support 60 hz. 50 hz works fine though, but I can only use my xbox as a DVD player in 50 hz.
is this on hd mode?, if so it needs to be on 1080i as 1080p will not work that high up. Also if you are not using the component lead then you should the picture is fantastic.
Was this helpful?
Yes
No
Popular Solutions for Videoseven LTV30C 29.6 in. LCD
The Samsung TV power on relay intermittently clicks on/off, sometimes the TV nearly comes on, and...
(More)
The Samsung TV power on relay intermittently clicks on/off, sometimes the TV nearly comes on, and then it stops. There is no regular time period in between clicks. I have fitted a switch in the cord to turn it completley off as this problem is driving me daft. Should be under warranty, as it has been doing this from new. Sureley there is an easy sort out for this, or thy'll have to admit it is a design fault!
Samsung plasma tv, model PS42S5S. The relay clicks and blue stand by led flickers in sympathy with...
(More)
Samsung plasma tv, model PS42S5S. The relay clicks and blue stand by led flickers in sympathy with the clicking. IC M806 has been changed as advised by a friend still no go. Anyone with similar problems?
