Question about Garland AF-5025 Deep Fryer
Garland deep fryer
Pilot lights are on but when you turn on the thermostat the burner is not lighting. What could be our problem ?
Gas valve not fully turned on
cattering hose not fully pushed into connector
thermostat tube inside oven broken (new valve)
Posted on Feb 19, 2008
Pilot lite working. When temp switch turn up to 365 you can here a click but gas burners do not light. Sometimes when you turn the switch back and forth the burners will light and bring oil to temp. and shut off but as oil cools burners do not come back on.
Posted on Mar 21, 2009
Cannot turn the on switch
Hi there!
Try pushing the knob lightly before turning to "on" or "off" position.
Jun 28, 2012 | Garland C836-1-35F LP - 35-lb Fryer w/...
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
Fryer lights off, but won't turn off when the thermostat is turned to the off position
The pilot flame will stay lighted even when the thermostat is off, you have to turn the gas valve knob to off position in order to shut the pilot flame.
But when burner flame remains on after shutting off the thermostat, the thermostat's mechanical contacts are shorted or remained engaged. If this is tha case, you have to replace the thermostat.
Jan 21, 2011 | Pitco Frialator SG18S Deep Fryer
Pilot will lite,but burners will not lite when you turn the thermo. up
Make sure gas valve is in the ON position after lighting the pilot. Try jumping the thermostat terminals together to see if burner comes on. Three things could cause this problem 1. bad operator on gas valve 2.low millivolts 3. thermostat not functioning
Aug 03, 2010 | Frymaster Dean SR42G Deep Fryer
Pilot light goes out when burner turned on
Replace the pilot generator. You are not getting the millivolts you need when you turn on the fryer.
May 28, 2010 | American Range AF45LP Deep Fryer
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
Burner will not come on
need tochange termal couple
Jun 01, 2009 | Imperial IFS40 Deep Fryer
Thermostat Issue DCS Fryer??
This sounds to me like the thermostat is not sensing and is reading a closed circuit all the time. You will probably need to replace the thermostat.
Aug 01, 2008 | DCS FSF-75 Deep Fryer
Garland AF-5025 Deep Fryer Logo
501 people viewed this question
Top Garland Kitchen Appliances - Others Experts
Paul Carew
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Garland Kitchen Appliances - Other Expert? Answer questions, earn points and help others
