Question about JVC KD-LX111 CD Player
Using an external mp3 player on my JVC KD-LX111
I recently bought a used car with a JVC KD-LX111 in it, and I'm trying to figure out if it is possible to connect my mp3 player to the system, so that I can listen to my mp3 player through the car's audio system.
I've looked at the user's manual, and I understand there is an adaptor (KS-U57) that I would need to connect an external unit. (I even think I've located the connection site--in the glove box.) But when I looked at the KS-U57 webpage on the JVC website, it only mentioned VCPs. I couldn't tell, from the picture, whether the ends of the adaptor would accept a standard headphone jack. (I have an extension chord with two "male" ends on it, so it the adaptor would allow it, I could plug one end into the adaptor and one end into the mp3 player.)
Any insights?
Thanks, in advance, for any help you can offer.
Marko
The KS-U57 is the correct adapter for that headunit. I am actually buying that same head unit for my car and I wanted to play my Zune through the radio. And i hate FM Modulators/Transmitters so aux is the only option i want. but you could buy the adapter from crutchfield http://www.crutchfield.com/App/Product/Item/Main.aspx?i=105KSU57&tp=1672&tab=other_items&viewAll=True hope that helps :)
Posted on Sep 22, 2008
You could try using an FM transmitter which plugs into the earphone jack on your Mp3 player, then all you have to do is tune the radio to pick up the transmitters frequency.
Posted on Apr 18, 2008
What does error 26 mean?
http://resources.jvc.com/Resources/00/00/97/49722ien.pdf
The above is the instruction manual.
Page 29, 2nd from end instruction may help.
Sep 06, 2015 | JVC KD-LX111 CD Player
I have recently bought a car that has a jvc kd-r601 stereo and I have disconnected battery and now it wont work, any ideas?
Reconnecting the battery causes a surge which can pop fuse. Generally there will be a fuse panel under the hood and underneath or on the side of a dash. There is also a fuse on the back of the stereo
May 14, 2010 | JVC KD-R600 Car CD/ MP3 Player
I need the code for a jvc kd-lxlllr radio cd player
as far as i know there is not code for this radio.
Mar 31, 2010 | JVC KD-LX111 CD Player
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
How to set time on a jvc kd r200 cd/mp3
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Nov 03, 2009 | JVC KD-R200 Car CD/ MP3 Player
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
LOST WIRING HARNESS TO DECK NEED A NEW ONE
YOU CAN ORDER IT FROM PACPARTS.COM OR ANDREWSELECTRONICS.COM
Sep 04, 2007 | JVC KD-LX111 CD Player
JVC KD-G420 in 2000 Toyota Tocoma
today's in-dash cd players are a 2 part mounting system. One part is the carrier chassis that is hard mounted to the dash. Then the cd player slides into part 1 and latches. To remove player from part 1, insert 2 long and narrow metal tools along each side to un-latch the player. The tools come with a new unit. To make these, try making them out of 1/16 inch thick metal and trimming to following dimensions: 6 inches long by 1/2 inch wide and at one end, narrow down to about 1/8 inch about 1 inch from the end. deburr all edges. This 2 part system is designed for anti-theft defense.
Aug 26, 2007 | JVC KD-G420 CD Player
JVC KD-LX111 CD Player Logo
597 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
