Model no MP8747. Message says 'no input on video'. I have changed to S video cable, same message came up. Projector is ten years old and I have never had any problems before. I use it for video presentations at meetings.
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
SOURCE: dell 1200mp
Hi jezzwhizz
You'll see that at the back of your Projector there is 2 VGA ports 1 in (normally blue) and 1 out ( normally grey ).
You are most probably using the grey one , switch it to blue.
SOURCE: Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
SOURCE: Relisys projector will not show presentation from laptop
the signal resolution may not match on the projector.
SOURCE: projector is mounted on ceiling mount. Projector
Buy a new Ceiling Mounted Projector then ,if looking for a ceiling projector mount with less maintenance & with extension pole. Order ceiling mounted projector online at Complement Ltd, for business or home theater use.Go to the link!!
Best Buy Ceiling Mounted Projector Complement Ltd
