Question about Kodak EasyShare DX6340 Zoom Digital Camera
Broken battery door
I see that others have replaced their battery doors...where can i get one from? My battery door has been busted for a while and I just decided to look into repairing it. Can anyone help me out? Thanks!
  • 2 more comments
  • fairy0113 Nov 18, 2007
    Thanks for your help!
  • Anonymous Dec 05, 2007
    i drop my camera and the battery door broke ,i would like to know if you guys can help me to fix it. i use my camera alot but with thebattery door broke i can't use it.coz it turns off on me.
  • zionnahboo May 10, 2008
    I need a new battery door for the kodak easy share digital camera DX6340. It is busted. Thanks!! Jan
  • acmob Aug 02, 2008
    I also need BATTERY DOOR REPLACEMENT for my camera. It appears that last lead given does not offer this replacment part. Any other suggestions as to where I can find this.
  • 48 Answers
This guy on eBay - Darntoothysam has them for replacement/repair
Posted on Nov 16, 2007
I even figured out how to replace the door. take out the 2 screws on the viewfinder side, and the 4 screws on the bottom, gently pry the body apart just enough so you can turn the door slighty sideways, and the door pops right out. Then install the new one, reversing the procedure making sure you get the tension spring back in the slot behind the pc card (green). Pretty simple, and Kodak wants $105.00 to do it.
Posted on Sep 09, 2008
I just got one from Kodak for free with $15 s/h.
2 Suggested Answers
  • 102366 Answers
SOURCE: Broken battery door
Choose your color from
Posted on Jun 14, 2010
Key remote won't lock the door change fuse and battery in remote still don't work
Common Reasons Why Your Car Door Isn't Locking Properly The key fob battery is dead: This is one of the most common reasons why your car door lock is not working. If your locks aren't working, replacing the battery in the key fob could solve the issue. The key fob is faulty: If the battery isn't the problem, the issue may be with the fob itself. If you go to your car dealer, they can hook the fob up to a computer and make sure that the programming is still good. If it's not sending a signal, the fob will likely have to be replaced. A fuse is blown: If one door doesn't work, but others do, the problem could be a blown fuse. Replacing the fuse will correct the problem. This is a cheap and easy fix The solenoid is bad: Again, if one door doesn't work, but others do, the problem could be with the door lock solenoid. Replacing it may require removing the car door panel You have a broken wire: If the lock isn't getting power, hold the lock switch either up or down, and then open and close the door repeatedly to see if the lock will work. If it works sometimes, you probably have a broken wire
Sep 28, 2016 | Cars & Trucks
On my 2000 ford crown vic. the power door locks work except for the drivers side. sounds like something is rattleing in the door. any ideas on what and how to fix
the power lock in that door may have broke the rod. remove the door panel to inspect its operation and replace the necessary part. hope this helps
Jan 31, 2011 | 2000 Ford Crown Victoria
Drivers door window replacement
Door glass bursting usually occurs due to heavy impact while closing the door or if the car is left in over heated environment. Some time it may occurs due to high beat of music system also.
Replacement of the window by self is not more complicated. You need to remove the door trim panel and other electrical connection from the doors.
Then clean the busted debries from the door thru' a vacuum cleaner. Purchase the right spare glass from the market. Remove the glass rail fittings from the position & fix the glass in the guide rails, then refix all the rails in position.
Put back the electrical connections & door trim in it place.
Jun 05, 2010 | 2001 Hyundai Elantra
I have a 1997 Oldsmobile aurora, My battery is dead, both front door handles are broken and so is my trunk lock. How do i get in??
Get a slim jim to unlock the doors, or bust the trunk key in and replace it later, or get another car just like yours and figure how to pop the hood from the outside, a lot of cars do it, but you have to know the secret. Hope this helps.
Mar 25, 2010 | 1997 Oldsmobile Aurora
2 door staked oven....the glass to the top is broken
you cannot you have to see if the complete door is available.
Nov 09, 2009 | Cameras
Broken battery door
Jun 02, 2009 | Kodak Easyshare M893 Digital Camera
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
Broken Battery Door
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Mar 28, 2008 | Fuji FinePix F40fd Digital Camera
Sony Mavica MCD250 -"Door Open" error message
have that opened up in a service center and tell them that you dropped it. they will tell you that the sensor is busted. that will have to be replaced. hope this helps.
Jan 29, 2008 | Sony Mavica MVC-CD250 Digital Camera
Kodak EasyShare DX6340 Zoom Digital Camera Logo
996 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
