Question about Microsoft Xbox 360 Elite Console
Xbox networking 1. how do I find the xbox from my PC2. how do i transfer media to the xbox drive3. xbox doesnt display most video files. why?
    Problem Solver:
  • 19 Answers
Re: xbox networking
You will have to set ftp up m8 you need ip of the xbox and fast transfer protocol program transfer as data or image theese files need to be made to image using ultra iso on pc first all xbox uses is linex
Posted on Nov 13, 2007
Re: xbox networking
I have an xbox elite and a netgear router both my xbox and pc connect through the router,when using both together my pc disconnects from the internet but my xbox is still connected to live.when i use pc through router but xbox not connected to xbox live,pc stays connected as soon as i try to go on xbox live pc disconnects from net and xbox goes on xbox live plz plz plz can any body help me i would be grateful
Posted on May 25, 2008
0 characters
3 Points
How do i get my xbox to play movies from the flash drive
  • 1
    Plug the flash drive into the Xbox 360 USB port in the front of the machine. Hold the middle button on the Xbox 360 controller to boot the console.
  • 2
    Scroll to the "My Xbox" screen with the d-pad. Move right to the media option you want to access. For example, the "Video," "music" or "Picture" options are available.
  • 3
    Select the type of media by pressing the "A" button. The next menu is the same for all three options. Highlight "Portable Device" and then press the "A" button again.
  • 4
    Choose the content from the next menu. On the right side, pick the file or folder of the media you want to display with the d-pad. Press "A" again to select the folder or to play the media file.
  • Mar 06, 2011 | Microsoft Xbox 360 Console
    When turn on power button shows up red and can't play any games
    This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs.
    1. Turn off the console.2.
    Remove the hard drive. For more information about how to attach or remove the Xbox 360 Hard Drive3.
    Reattach the hard drive, and then turn on the console.4.
    Obtain the latest automatic update for the Xbox 3602.gif. To do this, connect to Xbox Live.5.
    If you continue to experience this behavior, contact Xbox Customer Service.
    Nov 23, 2009 | Microsoft Xbox 360 Console
    Can't download CoD 5 map packs.
    No, The only way for some to download it for you is to give then your hardrive because thats what is saved on. I heard the COD 5 was banned in germany. is it true?
    Aug 13, 2009 | Microsoft Xbox 360 Elite Console
    Can not connect xbox to vista basic laptop (using an ethernet cable to connect console to pc) (pc is on wireless internet), have set media sharing on in Windows Media Player. Vista Basic does noy have...
    If it doesnt have media center, just right click and share any folders you want to stream through your xbox.
    Also might be useful to open file and media sharing in network settings.
    Apr 03, 2009 | Microsoft Xbox 360 Console
    call 1-800 4myxbox
    Sep 15, 2008 | Microsoft Xbox 360 Console
    Xbox 360 from PC
    1. In the XBox configuration menu you set it either for a dedicated IP address or DHCP. If you set it for a dedicated IP address you can simply check the configuration for that IP address.
    If you set it for DHCP then the easiest way is to download a network scanner (port or IP scanner) from a shareware site on the net - there are many free programs of this type just google for it.
    Use the scanner to identify the systems on your network by scanning from to and then eliminate the ones that you know - your router/firewall, PC's etc.
    2. Most XBox users transfer their files to their XBox using an FTP Server on the XBox. Depending on how modded your XBox is it may already have one. If not, there are many sites on the net that detail exactly how to set that up.
    Once it is configured and turned on, you simply access the XBox via the FTP Protocol - you can do that with an application in Windows or even using the command line.
    3. Because it does not have an application to do that already in place. Most users download one or several of the freeware video players from online sites and install them on their XBox.
    There are a number of websites online that offer step by step details on how to do this and even rate the various programs. Google is your best friend there.
    Nov 14, 2007 | Microsoft Xbox 360 Elite Console
    Xbox 360 modding
    You cannot transfer files to the Xbox 360, you can only stream the material eg songs or videos through it. You can put the items you wish to view on a usb memory stick, but again you cannot save them to your XBox 360 only play direct from the device you use to store the videos or music. You will also need XP media centre to use the media extender software, or even better Vista premium, XP home or Pro will not share the material with XBox because it cannot use the extender software.
    Aug 21, 2007 | Microsoft Xbox 360 Console
    Movie Formats To Work With Xbox 360
    As you may have heard, with the Xbox 360 Flash Fall 2006 System Update they are adding support for WMV video playback from new sources. Videos can be streamed from a PC running Windows Media Connect, Windows Media Player 11, or the new Zune client player, and can also be played from Optical Disc and most USB mass storage devices. For all these sources, only the WMV video file format and codecs are supported. How do I know if a video file will work on the Xbox 360? Currently only the Windows Media Video (WMV) file format and codecs are supported. If you have a file with a ?.wmv? extension, then the odds are pretty good that it will work. Technical details on the types of files we support can be found at the end of this post, but the easiest way to find out if a file will work or not is to just try it. Hopefully after you click play the video will show up on your display, but if the content is not supported you will simply get an ?Unplayable Content? message blade from the side of the screen and then be returned to the Video blade. How do I create videos that will play on my Xbox 360? Windows Movie Maker, a standard feature of Windows XPSP2, will output WMV video files compatible with the Xbox 360 console. Either use the default settings when you finish a movie and click ?Save to my computer,? or just make sure that the output video format you select shows the file type as ?Windows Media Video (WMV).? Videos will usually look best when they are closest to the original resolution that they were created with. Try to create video files at least 360 pixels high in vertical resolution in order to minimize content upscaling on the console. If you decide you want finer control of the output video file format, download a version of Windows Media Encoder ( and then start encoding away. Optimal size and bitrate settings will vary depending on the source material you are encoding. As a general guideline though, 1.5 Mbps is a typical bitrate that should be suitable for most standard definition content, and 8 Mbps is a common bitrate for high definition content. Can I get more technical details about the kinds of files you support? WMV video files with the extension ?.wmv? are stored in a generic file container format known as ASF. ASF files can contain many different types of codecs within them. Xbox 360 supports most common WMV video codecs, as seen in the following chart: Supported Video Codecs: Name FourCC Windows Media Video 7 WMV1 Windows Media Video 8 WMV2 Windows Media Video 9 WMV3 Windows Media Video 9 Advanced Profile WVC1 There are some files with ?.wmv? extension that may play on a PC, but are unsupported on the Xbox 360 console. Windows Media Screen, Windows Media 9 Image (Photostory), and some older Microsoft codecs are unsupported, as seen in the following chart: Unsupported Codecs: Name FourCC Microsoft MPEG-4 Video Codec V3 MP43 Microsoft MPEG-4 Video Codec V2 MP42 Microsoft MPEG-4 Video Codec V1 MP41 Windows Media Screen V9 MSS2 Windows Media Screen V7 MSS1 Windows Media Video 9 Image WMVP Windows Media Video 9 Image v2 WVP2 ISO MPEG-4 Video V1 MP4S Anamorphic content with nonsquare pixels is currently unsupported on Xbox 360 console, and will be displayed as if the pixels were square. If you want to play such content on your console, it is recommended that you re-encode the content in a square pixel format.
    May 17, 2007 | Microsoft Xbox 360 Console
    Info from my comp to the 360?
    The only way to see video files from the comp on the 360 is to stream the files You can do this only if u got Windows Media Center And if so the only formats it plays are: , DVR-MS, MPEG-1, MPEG-2 WMV So if you want to see movies in other formats you got to convert them first Good luck
    Feb 23, 2006 | Microsoft Xbox 360 Console
    Information from computer to 360
    The only way to watch video files from the computer to the 360 is to stream them, which can only be done if you have Windows Media Center. Even then, the only formats that it would play are DVR-MS, MPEG-1, MPEG-2 and WMV. So if you want to watch movies that are in quicktime, divx, avi formats or any other, you would first have to convert them into the supported formats.
    Feb 22, 2006 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Elite Console Logo
    500 people viewed this question
    Top Microsoft Video Game Consoles Experts
    Troy Gorman
    Troy Gorman
    Pablo Gonzalez
    Martin Murray
    Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
