YouTube Videos Logo
A
Anonymous Posted on Mar 10, 2015
Youtube videos of Elmo f0r babies
Elmo
Helen Elena
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 13 Answers
  • Posted on Jun 09, 2015
Helen Elena
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
13
Questions
Helped
1876
Points
34
Which kind of video does it refers to? I fall in love with Muse band by watching a youtube video. And I buy their tickets from en.damai.cn. I will watch their concert a few months later. I'm so excited with it!
Hokey pokey elmo doesn't move at all. Have put new batteries in it but doesn't help. Any suggestions??
Hello, David -
Did you replace all 4 batteries? If not, Hokey Pokey Elmo takes 4 AA batteries:
https://service.mattel.com/instruction_sheets/B6678.pdf
If all 4 batteries are new, the problem may be with the circuit board or wiring.
This video of disassembling a Tickle Me Elmo may be instructive if you wish to open up your Hokey Pokey Elmo and check on the wiring and circuit board:
https://makezine.com/2016/04/08/tickle-me-elmo-how-about-dissect-modify-elmo/
I suspect Tickle Me Elmo and Hokey Pokey Elmo were built the same way.
More about Tickle Me Elmo (which may prove helpful with Hokey Pokey Elmo):
https://www.ifixit.com/Answers/View/368936/How+to+rewire+it+up
(Quote)
Sometimes there is just a broken wire in the box due to the vibrations made by the oscillator and or the batteries being removed and replaced activity. A blown circuit is rare unless someone tried to fix it and wired it wrong. It only takes a millisecond to blow a component if wired wrong. Same holds if a circuit gets wet ! Best advice is to remove the power source i.e. the batteries; and dry everything before turning it on !
The circuit itself is a small card. There are a few discrete components that are wired to the card. Check the connections. If you don't know exactly where the broken wire goes, don't guess ! It could be the end of Elmo as you knew him ! Get advice ! It could be the difference of a quick soldering and having to replace the entire unit. Don't be afraid of opening it up while just checking. Just put the screws back the way they came out.
Do it all with the batteries removed, please !
If the Device does nothing, it maybe the on/off switch. The batteries are obviously the first thing you checked, right?
If it talks; but, doesn't wiggle, its the oscillator connection.
If it wiggles but doesn't talk, it may just be the speaker wire.
If it talked but didn't wiggle and someone worked on it and now it does nothing, the person blew a component on the board. Most likely a capacitor. They don't take change in polarity very well ! The whole board is as cheap as the sum of its parts and labor.
(End quote)
If you get Hokey Pokey Elmo back to working properly, be sure to remove all 4 batteries when not in use and stored for a period of time, so that the batteries do not corrode and ruin Elmo.
Best wishes.
2answers
Chords needed for elmo 400af
yes, but i dont even have a cord yet. what cord should i buy?
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Hokey Pokey Elmo sings and moves his hand and foot but stopped shaking and won't turn around in a circle. It worked fine then stopped working we changed the batteries and it worked a short time then quit...
Hi ms_debbie13
    How to Activate
  1. This plush, shiny red Elmo is standing with his arms up above his head. One foot is lifted slightly off the floor and the other is on the floor. On that foot, there is a swivel allowing Elmo to turn, the battery door and the on/off switch. Turn Elmo on and stand him upright then squeeze his left hand to begin his song.
    Elmo really moves his right arm and leg in time with the song, and also turns in a circle. When the song is done Elmo says, "Whew.. that was fun! Elmo's pooped!"
  2. Alternative Mode
  3. The alternative mode is Elmo trying to keep up as the music keeps getting faster. If Elmo falls over he will say, "Woops!" and then he will thank you when you set him back upright.
Jan 30, 2011 • Toys
My elmo document camera TT02s is showing widescreen. How do I fix that?
Not sure what you mean by wide screen. Are you viewing on a projector, TV or monitor? Or via USB to your PC?
Feel free to email me at [email protected] and I am sure we can assist you.
VSC is one of the largest Elmo dealers in the US. You can view the new Elmo TT-02rx at:
http://www.shopvsc.com/Elmo-TT02RX-Digital-Document-Camera-p/elm-tt02rx.htm
The power button flashes but there is no light.
Elmo TT02 models come with a five year factory warranty, and from my experience, Elmo will usually repair your camera even if it is out of warranty at little or no charge. Download the warranty service form from the following link:
http://www.elmousa.com/files/service1.pdf
Fill it out with your contact info and describe your problem. Box up your camera along with the service form and ship it the address on the form. Elmo will repair within several days and return it to you.
Please feel free to contact me at [email protected] or www.shopvsc.com if you have any additional issues. VSC is one of the largest Elmo dealers in the US.
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
2helpful
My ELMO video presenter is not working. When I connect it to the video projector via s-video cable, it no longer shows an image, but the projector recognizes there is a signal. It recently fell off of a...
you'll have to check the elmo usa website. you can either send it to elmo themselves, or to one of their authorized service centers (website). if the camera itself is damaged, it's pretty expensive. it may just be the s-video socket.
Top YouTube Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
 Grubhead
Grubhead
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
