Dishwashers Logo
A
Anonymous Posted on Mar 10, 2015
I have a Frigidaire dishwasher it is showing a code cl which means its not closed. I just replaced the latch with a bran new one and still is reading the code. any suggestions
  • Official Brand Answer 2,267 Answers
  • Posted on Mar 13, 2015
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288910
Points
2557
Good Afternoon friend, I appreciate your post!
From what you have described your Frigidaire dishwasher is displaying an error code of "CL" and you have replaced the latch. Since the latch has been replaced it could be a problem with the wiring harness or main control. I would recommend having a professional out to perform a diagnosis and this will help you to avoid any unnecessary part purchases. Best of luck! -Matt
What does CL code mean?
The Frigidaire Appliances company designed most of its dishwashers to visually alert and display to users that the door is ajar, via the "CL" code. The dishwasher won't start pumping in hot water or rotating the spray arms until the door is secure.
How to Fix a Frigidaire Dishwasher Showing a "CL" Code ...
My dishwasher FDB2510LCC1 get a cl code while washing and stays running on the wash stage until it is shut off
Hello Randy, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher is displaying an error code of "CL" this means close door. The dishwasher may not be sensing that the door switch is closed. The "CL" means that you could have a possible issue with the main control board or door latch. I would recommend checking to make sure the latch does not have any visible damage. This could also be a miscommunication within your dishwasher and a reset may help clear it out. In order to reset the dishwasher you would flip the household circuit breaker off for at least ten minutes. We hope this information is helpful to you. -Matt
I have a Frigidaire dishwasher model # FDB2415LFSO with a blinking CL code. When I try the normal wash cycle button the drain pump runs and the CL light blinks continuously and nothing more happens. The...
Good Afternoon friend, thank you for your post!
Based off what you have described you have performed multiple tests to your Frigidaire dishwasher and it continues to display a "CL". That code does stand for close door which can mean that the door switch is sensing it is opened. For this error code it could be a possible problem with your door switch or main control. I understand you stated that the control did not appear to have a burn inside of it so it is easy to assume that the door latch could be the issue. Remember if you are not a professional technician this could be the start of unnecessary part purchases. I hope this information is helpful to some degree. -Matt
1helpful
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
2helpful
When i close my dishwasher it makes a click but still shows CL and doesn't start. What can i do?
Hi
Daniel
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Daniel
2helpful
2answers
Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Frigidaire pld3460rdc1 the dishwasher flashed CL when the door is closed.
The CL is letting you know that the door was closed. If it continues to show CL it means you need to close and latch before the cycle will run. If it just flashes your okay.
Cl code problem on fridgidaire dishwasher
Code "Cl" on Frigidaire means the door is not closed. Could be a bad door latch.
Dec 15, 2008 • Dishwashers
5helpful
2answers
Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Mar 24, 2008 • Dishwashers
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
