Question about Olympus D-555 Zoom Digital Camera
Olympus ilp 100 photo printer
Ilp 100 printer does not feed photo paper through the system. It seems to work when I hit the print button, the arm pushes up, the traction wheel spins, but does not grab paper. I can carefully manually feed the paper and then it works fine to finish just that photo
  • Mark Brooks Jun 03, 2008
    Olypus ILP-100 printer does not feed the paper. The paper is lifte and the traction wheel turns, but the paper does not feed. Please help!!!
    New Friend:
Place something about 3/4" under the end of the tray to tilt it
Posted on Jan 28, 2013
I had the same problem. My guess is something in the printer broke in some fashion, and this is a common weak point of the printer itself. I ended up buying a replacement printer. I must say that I LOVE the prints that this printer makes, and it's so easy to use that my wife and 14 year old son can use it with no problems. The prints are FANTASTIC, and look just like a film photograph print !!! It is that good! And... the cost is about the same for film prints (with none of the cost of the film or developing), with all the convenience of doing it at home, on demand. WOW !
Posted on Jun 19, 2008
Make sure you are using the correct type of paper. If you aren't using the long kind with the perforated edges then it isn't going to feed.
Posted on Jun 05, 2008
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
My 1290 fails to feed the paper. It seems that most of the time the paper is picked up at one edge so the paper crumples
When you experience damage to the paper when feeding it means that it is hitting something in it's path. Open the printer and check the path of the paper for any foreign objects like torn paper, staples,and the like. And if you have printed any labels, part of the label maybe caught on one of the rollers.
May 18, 2010 | Epson Stylus Photo 1290 InkJet Printer
Constant jamming recently
Could be 2 things..
First Check close and make sure there are not small bits of paper in the feeding arms rollers etc.. any place paper passes make 100% sure. Second adjust the tension from the feeding arm and make sure the paper path to the printer is clear.
You can also hit it with a few shots of Dustoff
Jun 17, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Olympus cartridge
Here is the link for the camera manual
As far as a manual for the printer itself you may want to call Olympus Technical Support and they can probably email you a manual. Their telephone number is 888-553-4448 option 5 and then option 1
Jan 14, 2009 | Olympus D-555 Zoom Digital Camera
Need help setting printer to print regular size
On your printer, there might be a button saying Enlarge/Reduce. Keep hitting it until you get 100%. Good Luck.
Nov 15, 2008 | Cannon Canon i960 Photo Printer
Epson R320 Paper Feed Problem
Biggest POS in the world. Brand new and doesn't work right. Will never buy from this company again!
Oct 02, 2008 | Epson Stylus Photo R320 InkJet Printer
Canon ip6000D
use good quality paper for printing. clean the feed roller or get the printer serviced from the authorized dealer.
Aug 09, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Olympus D-555 Zoom Digital print driver Ilp-100
go to the olympus website and find software for the D-555 digital camera it will also have the printer driver for the ILP-100
Jul 23, 2008 | Olympus D-555 Zoom Digital Camera
Olympus D-555 Zoom Digital Camera Logo
887 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
